Old 03-11-2017, 06:11 AM   #1
nikp
Drives: 2016 BRZ
side skirt holes
Hi
I drilled holes for my HT auto side skirts. Getting rid of my side skirts now.
What can i fill the small holes with?
Thanks
nikp is offline   Reply With Quote
Old 03-12-2017, 11:02 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
If the holes are on the underside of the car use some black silicone/RTV to seal them up and insert a christmas tree-styled push pin into the hole.
Old 03-13-2017, 01:29 PM   #3
sirsol66
Drives: 2013 FRS- Hot Lava
You can find plugs at home depot, lowes, or similar.
BUT, I would say take off the side skirt, touch up the holes with paint, let them fully dry (without driving the car so you dont get water INTO the rockers), apply a mix of white lithium grease+ motor oil (small amount) to the holes (try to spray inside the rockers), and then put in the plugs with a small dab of RTV to seal them.
And also worth nothing this is why I tell people to never do this style side skirts. The rust concern is huge.
sirsol66 is offline   Reply With Quote
Old 03-13-2017, 02:52 PM   #4
Brayden_23
Drives: Asphalt 2015 FRS
Quick sidebar - which side skirts don't require drilling?
Brayden_23 is offline   Reply With Quote
Old 03-13-2017, 03:16 PM   #5
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Bondi, gum, plugs like on 1st page.
Packofcrows is offline   Reply With Quote
Old 03-14-2017, 11:39 AM   #6
nikp
Drives: 2016 BRZ
When installing side skirts i sprayed primer into the holes I drilled. I'll get some plugs and seal it off with RTV.
Old 03-14-2017, 12:08 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
My Bayson R STI replicas didnt. Screws at the end and brackets on the bottom with 3M tape on the sides.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Brayden_23 (03-14-2017)
Old 03-14-2017, 01:06 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I just installed bottomline side skirts and I only drilled into plastic in the car. It's not metal between the under carriage and the side of the car. That textured painted rocker panel is plastic. I didn't bother putting anything in the holes except the mounting screws. No chance of rust.
Old 03-14-2017, 01:24 PM   #9
sirsol66
STI (same as series blue), TRD (US or Japan), or nur spec.
The Following User Says Thank You to sirsol66 For This Useful Post:
Old 03-14-2017, 03:41 PM   #10
JT.86
Drives: Scion FRS 2016
Anyone know if Varis side skirts need drilling? (Arising II)
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
Old 03-14-2017, 04:04 PM   #11
JoeC
Drives: Subaru BRZ Limited
It is???
JoeC is offline   Reply With Quote
Old 03-14-2017, 05:08 PM   #12
sirsol66
Originally Posted by JoeC View Post
It is???
^^No its not. The coating is a plastic sprayable coating we call PCV, but the rocker is metal.
Old 03-14-2017, 06:12 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
funny, what I just drilled out was plastic. No metal.
Old 03-14-2017, 07:29 PM   #14
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by nikp View Post
Hi
Thanks
A*
Scrappydoo is offline   Reply With Quote
WTB: STi OEM Side Skirt (Passenger Side) scubastove Want-To-Buy Requests 6 09-12-2017 02:28 PM
WTB: 1 OEM STI Side Skirt (passenger side) x1UP Want-To-Buy Requests 0 03-19-2015 12:26 AM
WTB: 1 OEM STI Side Skirt (passenger side) x1UP NY / NJ / CT / PA 0 03-18-2015 11:33 PM
WTB: Vertex Side skirt or Origin lab skirt Vesalera Want-To-Buy Requests 0 03-16-2015 09:00 PM
