Old 03-10-2017, 08:15 AM   #1
GT86Olli
Drives: GT86 Inferno Orange
Light Weight Low Offset wheels
Hi,
I'm looking for a set of lightweight wheels with a low offset.
I drive a GT86 with Rocket Bunny V1 Kit and actually mounted SSR Professor SP1 in 9.5x18 -3 and 10.5x18 -26 (functional setup for track)
They fit perfectly without spacers needed and for a threepiece wheel, they are light (10.6 kg / 23.4 lbs).
But I thought about to change to 17" and a square setup so I'm looking for a set of 9.5x17 or 10x17 ET 0 to -30 with 265/40 17
Any ideas? I searched for long time, but can't find anything.
There are Watanabe in 17" I know about. 9.5x17 -19 all around and 9 kg (19,8 lbs) per wheel, so quite perfect!
But that offset is too low for the front with 265/40 tires...
So any other wheels known? Thx guys!
GT86Olli is offline   Reply With Quote
Old 03-10-2017, 11:37 AM   #2
richie incognito
Drives: BRZ- all the colours
I'm not in tune with rocket bunny fitment but I find it hard to believe you will be able to go with a square set up and have it work without either the front or tears looking off. I would expect you will either rub in the front or sunk in the rear.
richie incognito is offline   Reply With Quote
Old 03-10-2017, 12:55 PM   #3
GT86Olli
A little spacer (little!) at the rear would be ok.
But yes, that's the problem and why it's so difficult to find wheels.
In case of the Watanabe -19 in the front would be too aggressive and in the rear I would need 15mm spacer
Old 03-13-2017, 05:32 AM   #4
GT86Olli
No ideas?
Old 03-13-2017, 07:55 AM   #5
sqd
sqd's Avatar
Drives: '13 SWP GT86
Originally Posted by GT86Olli View Post
No ideas?
I can't help you unfortunately, but could you post a few photos of your car with the SSRs, please?
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 03-13-2017, 09:06 AM   #6
chargedup
Drives: SC BRZ
kenisis, fiske, and ccw are all pretty damn light. or te37's
chargedup is offline   Reply With Quote
Old 03-14-2017, 06:11 AM   #7
GT86Olli
It's not finished yet, paint is actually in progress.
Here some pics with the unpainted kit on the car:
Thanks!
Old 03-14-2017, 06:47 AM   #8
sqd
sqd's Avatar
Looks great, thanks! What tire sizes are you using in these photos?
IG @squareddesign
Old 03-14-2017, 07:29 AM   #9
GT86Olli
Thank you!
245/35 18 front and 285/30 18 rear. Toyo Proxes T1 Sport
They fit perfectly with the rocket bunny V1 fenders
Old 03-14-2017, 02:44 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
TE37V 17x9.5 upwards to 10.5" all around, and add 500>514 bolt on adapter spacers is your only choice.
But if you go the bolt-on spacer route, you can run almost any type of wheel out there.
Alternatively, you can run something like Work Meister S1R that allows you to customize your offset with 5-100 bolt pattern.
-alex
Old 03-14-2017, 06:42 PM   #11
sqd
sqd's Avatar
Thank you!
Great info, thank you. You aren't selling the SSRs?
IG @squareddesign
Old 03-15-2017, 06:23 AM   #12
GT86Olli
@mav1178
Yeah I know but I want to avoid adapters... so no 5x114 possible
Work Meister are 3 piece, too. So I can go the SSR route also
@sqd
I would sell them. You're pm'd, Sir!
Old 03-15-2017, 08:11 AM   #13
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
What weight per wheel would you consider light?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-15-2017, 10:28 AM   #14
GT86Olli
For that size everything around 9 kg (19,8 lbs).
Per rim of course.
► APEX | FR-S/BRZ Light-Weight Track Wheels APEX Race Parts Wheels and Tires 7 05-27-2016 03:18 AM
Light weight forged wheels? slyphen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-22-2015 01:35 PM
FS- Kosei K1TS 17x7 wheels 50mm offset- Autocross LIGHT! solort Wheels and Tires 2 07-09-2015 04:08 PM
Light weight wheels vegasfrs Want-To-Buy Requests 0 03-21-2014 11:31 PM
Light weight wheels <6.8kgs (15lbs) diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-17-2012 11:32 PM
