FRS 10 series #0239
Drives: #0239 FRS 10 series silver ignition
OFT and Stock headers and exhaust
whats going on everyone,
back again with another question. so I was looking into getting coilovers and then getting the OFT buuuuuuut, I can't stand this idle dip any longer! I'm just going to get the eibach sportline springs and get the OFT to get rid of this dip. my question is, will I be able to run (and get rid of the torque dip) and tune the OFT with my stock headers and exhaust? if this has already been asked and replied to please redirect me. I was at a meet last night and I talked to a guy that was running OFT on stock headers and he said it cleared it up almost gone. I'm trying to get outside perspectives to see how true this is. thanks in advance
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239 |
@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
In short, yes. I run stock headers + exhaust (only a Berk HFC FP) and I can confirm that torque dip is gone and oft allows a lot of tuning to be had even with stock/oem parts.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
@anthonysestito
http://www.ft86club.com/forums/showthread.php?t=71157
There ya go. Sent from my iPhone using Tapatalk
FRS 10 series #0239
so Im able to run it but I would have to run it on the 1st tune and not the second tune correct? the dip is completely gone or is it just pushed down to 2k?
10 series #0239 |
#5 | |
@anthonysestito
Correct, you'll run STG 1. http://www.ft86club.com/forums/showthread.php?t=71157 Check out that thread. Sent from my iPhone using Tapatalk
Drives: 15 BRZ LTD, 05 FXT
Even better, take the stock headers off, bash the cat out, and run OFT Stage 2 EL.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Huge E85 fan!
Drives: 2016 Scion FRS
Stage 1 helps with the torque dip but doesn't eliminate it. Stage 2 with a gutted cat evens out the torque dip but the car still doesn't pull like it should. The torque should build steadily with increased RPM but in the erstwhile torque dip it just plateaus and builds again after 4k or so. Check out some stage 2 dyno sheets and you see it. Still stage 2 + gutted cats makes the car a lot better- like a new car.
Drives: GT86
I run the Stage 2 EL (Petrol) tune on my OEM-Header HFC.
From the logs it was worse on stage 1, it likes stage 2 much more. Dip is gone for me. Hell lot of a difference a highflowcatalyzer can make. |
FRS 10 series #0239
So you have a high flow cat on your front pipe? Or you gutted the cat on the headers and left the front pipe?
10 series #0239 |
#10 |
Drives: GT86
Modified OEM header. stock-cat out. HFC in.
Frontpipe is umodified. Logs are looking pretty good. Little FLKC but nothing significant. |
#11 |
Drives: 13 frs red
If you're purely street driving it I would skip the coil overs and put a good header and oft tune. E85 if its available and you wont be worried about a torque dip.
#12 |
Drives: Raven FR-S
Concur with above. E85 + tune = win. Headers make it even better.
| Tags |
| oft, open flash tablet, stock headers, torque solution |
| Borla UEL headers w/stock exhaust VIDEO | BRAWL | Engine, Exhaust, Transmission | 37 | 06-21-2019 04:47 PM |
| Stock exhaust and stock headers | lizbrayan | Engine, Exhaust, Bolt-Ons | 13 | 08-15-2016 07:55 PM |
| Request: Headers and OP with Stock Exhaust Sound Clips | HachiEnam | Engine, Exhaust, Transmission | 8 | 09-30-2015 01:53 AM |
| headers w stock exhaust | DanoFA20 | Engine, Exhaust, Transmission | 4 | 02-01-2013 06:41 PM |
| What you guys do with stock headers and exhaust after swap? | WatchmaN | Engine Swaps | 6 | 08-09-2012 06:26 PM |
