Old 03-07-2017, 12:10 AM   #1
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Driver rear lower after settling, heaviest corner?
Hey fellas, I'm running ST coilovers and after a couple weeks of driving, the fronts seems to settle pretty evenly between the driver and passenger side, within 1/4" of each other.
The rear is the different story, the driver-side rear is a full 1" lower than the passenger side with the perches on the coilovers set exactly the same, whenever I lift up the car from the rear diff it's always tilted to the left which leads me to believe the driver-side rear is much heavier hence the height difference?
Anybody notice this with any other suspension? In order for me to even it out, I have to raise the driverside rear perch about 1" higher than the passenger side, which definitely would affect the spring preload am I right?
Dan37BRZ is offline   Reply With Quote
Old 03-07-2017, 12:30 AM   #2
jamal
jamal's Avatar
Drives: Legacy GT
Has the car been corner balanced? Do you have adjustable endlinks?
I would highly recommend both.
jamal is offline   Reply With Quote
Old 03-07-2017, 12:33 AM   #3
Dan37BRZ
Senior Citizen
Not corner balanced, just regular alignment. No adjustable endlinks either.
Old 03-07-2017, 12:54 AM   #4
swarb
You are over thinking it, and it isn't the first time.
http://www.ft86club.com/forums/showthread.php?t=115625
http://www.ft86club.com/forums/showthread.php?t=115075
What does the rear diff have to do with anything? It doesn't.
1 inch on the suspension does not equal 1 inch at the wheel.
You were fine a month ago.
http://www.ft86club.com/forums/showp...4&postcount=22
Stop over thinking it.
Pull the suspension, measure, compare, reinstall. And swap the corners.
WTB: Front Lower Control Arm DRIVER Side DaveUsagi Want-To-Buy Requests 1 09-19-2016 05:34 PM
looking for heaviest shift knob Dr. BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 12-18-2015 11:14 PM
WTB: driver front lower control arm Edison86 Want-To-Buy Requests 0 09-26-2015 01:22 AM
Need left driver side lower control arm jrsd1 Want-To-Buy Requests 0 08-21-2015 11:38 AM
WTB: Driver Side OEM Front Lower Control Arm 86nub Want-To-Buy Requests 1 09-08-2014 12:44 AM
