Old 03-03-2017, 12:18 PM   #1
allowe
allowe's Avatar
Recent alignment
I just got my car aligned. Sorry if this is a stupid topic but looking at the right rear. Is that off by a lot or is it something that isn't that bad
allowe is offline   Reply With Quote
Old 03-03-2017, 12:38 PM   #2
strat61caster
strat61caster's Avatar
Not unusual for stock, 0.7 is a bit larger than usual though, most are 0.5 or less.
http://www.ft86club.com/forums/showp...89&postcount=2
http://www.ft86club.com/forums/showthread.php?t=97321
And while googling for this, Dezoris thread on alignment is worth a read given all the alignment questions flying around this month.
http://www.ft86club.com/forums/showthread.php?t=25001
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
allowe (03-03-2017), sugoi (03-03-2017), Ultramaroon (03-03-2017)
Old 03-03-2017, 01:25 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I just thought of something I forgot to mention in your other thread. Consider all the rubber bushings that are used in the suspension. None of those pivot. They flex, and when they do, they load up just like springs.
It's important to settle the car at it's neutral resting position before torquing down those joints.
I bet your right rear is lifted ever so slightly higher than your left. That will affect negative camber exactly as shown in your print.
allowe (03-03-2017)
Old 03-03-2017, 02:46 PM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
At least the front end is pretty even. lol
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
allowe (03-03-2017)
Old 03-03-2017, 05:51 PM   #5
allowe
allowe's Avatar
That was a funny article (the part where he mentioned how they never get alignment right). Thanks for your post!
I went back to him and we argued back and fourth and he won't even look at my car saying how "it's in the green, I did my job".
I'm talking to someone else who might do it for super cheap for just that rear tire.
In your opinion do you think it's worth me going thru with aligning it? I'm paranoid about tire ware and overall performance
Old 03-03-2017, 06:08 PM   #6
bfrank1972
Drives: 2013 FR-S Argento
Camber you won't likely notice a difference, that rear toe looks pretty uneven though...
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
allowe (03-03-2017)
Old 03-03-2017, 06:19 PM   #7
strat61caster
No, I do not think you will get any significant improvement over the posted numbers without installing aftermarket lower control arms in the rear.
Your toe looks good to me, you probably wouldn't notice the 0.01 degree of difference to get it 'perfect'
ineedyourdiddly
allowe (03-03-2017)
Old 03-03-2017, 06:23 PM   #8
allowe
allowe's Avatar
Well everything looks fine except the rear right camber which is what I went to get the alignment for.
I do 90 degree corners at 40 km an hour (if that makes any difference...yea stupid I know)
Thanks all for your posts
Old 03-03-2017, 06:39 PM   #9
bfrank1972
Sorry regarding toe - read it wrong. Your settings are fine except you need camber bolts in the front
allowe (03-03-2017)
Old 03-03-2017, 06:51 PM   #10
allowe
allowe's Avatar
Do you mean the rear haha?
Old 03-03-2017, 07:20 PM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
Front. It badly needs negative camber for better cornering. Won't be in the green though.
C
Old 03-03-2017, 07:25 PM   #12
It is fine. If you saw my after sheet with all the red and my rear 3.5 camber you would shit yourself. Still on my original summer tires after 50K miles and no bad wear though.
Old 03-03-2017, 09:12 PM   #13
bfrank1972
Nope, add SPC cam bolts in the upper holes, maxed out, with a little shoving you can get them a little beyond -1.5 in the front. You'll be really surprised how it improves the responsiveness of the front end. One of the biggest bang for the buck mods for this car IMHO.
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
allowe (03-04-2017), wparsons (03-07-2017)
Old 03-04-2017, 02:45 AM   #14
allowe
allowe's Avatar
Hey thanks for your post! Ok do I need 4 bolts or 2? I'm reading up on how I should either have 4 or switch the bottom bolt for the top one or something along those lines.
Also, is there a tool you can buy that isn't super expensive (like the actual hoist with the laser thing) that does alignment accurately?? I can't seem to find something digital that's accurate.. I figured if I want something done right, I have to do it myself. That's literally always been the case for every car I've ever owned.
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
Some recent observations.. MuseChaser Scion FR-S / Toyota 86 GT86 General Forum 28 12-12-2015 07:02 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
ISC Lower Control Arms and my most recent Alignment NorCalGirl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-27-2014 02:34 AM
Recent car accident Sea1monkey2 Other Vehicles & General Automotive Discussions 19 06-21-2011 08:27 AM
