Old 03-02-2017, 11:19 PM   #1
VVT4ME
VVT4ME's Avatar
Drives: 2014 Scion FR-S
Click sound outside car when pushing clutch in in neutral...
Question for the community...when my car was running today in the garage and I could listen, I could hear an audible 'click' or similar noise when pushing the clutch in and out while the car was in neutral and stationary. When the engine was off, no noise, so I'm assuming it's a moving part. Is this normal? I'm a relatively new owner (1 month) so I'm trying to sort out what is normal and not normal/needing attention. Any thoughts would be appreciated, thanks.
Throw out bearing? Car has 24k miles, bought it with 23, owned it a little over a month.
VVT4ME is offline   Reply With Quote
Old 03-03-2017, 01:09 AM   #2
humfrz
Allow me to refer you to our "clutch noise" expert @Ultramaroon.
Does it make the noise when you are pushing the clutch in ...... or letting it out ..... or both.
Does the noise persist when the clutch is pushed in and held in .. ??
Can you hear it while the engine is running and the clutch is NOT pushed in .. ??
humfrz
Old 03-03-2017, 01:22 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Staying tuned. @humfrz, you covered all the bases.
Old 03-03-2017, 03:33 AM   #4
VVT4ME
VVT4ME's Avatar
Makes the noise both going in and out
Noise does not persist when held in (like I said, sounds like a click or tap)
And it doesn't make the noise when not.pushed in.
It makes the noise in the act of pushing the pedal.
And the noise does not occur when the car is off (not running)
Old 03-03-2017, 11:19 AM   #5
humfrz
OK, @Ultramaroon ....... you're up .....
humfrz
Old 03-03-2017, 12:29 PM   #6
Ultramaroon
not playing cards
Damn. I need a clip. Can you feel the click in your foot? That's a new one.
Old 03-03-2017, 03:39 PM   #7
tinma
Drives: '13 BRZ
I actually have the same noise... Just left it... So Im also in for answers now that Im feeling not as lazy lol
tinma is offline   Reply With Quote
Old 03-03-2017, 11:38 PM   #8
humfrz
hmmmm.........have you checked to make sure the fluid level is up to full .. ??
It's a long shot, but you may consider changing and bleeding the clutch hydraulic system.
Even if there isn't air in the system ....... at 24,000 miles, it sure wouldn't hurt anything.
humfrz
Old 03-04-2017, 10:50 AM   #9
extrashaky
Drives: 2014 BRZ Limited
Mine has been doing that for 40K miles. It's just another noise these things make.
Rattling Sound In Neutral tekFRS234 Issues | Warranty | Recalls / TSB 5 07-16-2015 10:23 AM
Loud clicking sound when slowing down in neutral I like the tuna here Issues | Warranty | Recalls / TSB 1 05-02-2015 12:03 AM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 08:24 PM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 09:50 PM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 06:53 PM
