Old 02-26-2017, 01:25 PM   #1
Dakines
Looks like i screwed for my turbo tune
Thanks a lot of
Dakines is offline   Reply With Quote
Old 02-26-2017, 06:09 PM   #2
steve99
Originally Posted by Dakines View Post
I bought a turbo kit, and i try to tune it, but the afr allways thin as above 15.
i had scaled maf with YIKES CL-MAF Worksheet and scaled the map whith omni3bar sensor. maybe my tune methods is wrong.
so i wanna know which tables should i need do it , did anybody tell me.
attached the tuned rom file and stock rom file, link is lop data(fullgas and Cruise control )
http://datazap.me/u/q110287/11%E7%89...&data=1-12
Is your maf housing same size as the stock maf housing diameter. If you maf housing is a larger diameter then i think you maf scaling is incorrect. For bigger housing diameter you should have larger flow numbers for same volts.
standard injectors, is scaling correct
Check you direct injection open tine is not more than about 6m/s and your ports about 15m/s that about the limits you want with some in reserve.
maybe use the VGI maf scaling tool its much easier than YIKES
http://www.romraider.com/forum/viewtopic.php?t=10481
maybe also look at these tunes for early SBD turbo kits, think they were about 7 psi should give you some ideas.
just scroll to top of page for tunes
http://www.ft86club.com/forums/showthread.php?p=1855197
Old 02-27-2017, 04:37 AM   #3
Dakines
I fixed the MAF scaling in CL afr is close 14.7 in CL,but my open loop allways lean,my command afr is above 12,but actual AFR is so lean, about 13.5-14.7. i scaled the maf but it doesn't work
If i want open loop to rich,how should i do?
Old 02-27-2017, 05:21 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you changed the MAF Limits and Load Limits?
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-27-2017, 08:37 AM   #5
"Looks like i screwed for my turbo tune"
Old 02-27-2017, 09:00 AM   #6
jasonojordan
Drives: 2013 satin white brz limited
Hey some people are willing to take tunes as payment apparently...
jasonojordan is offline   Reply With Quote
Old 02-27-2017, 09:11 AM   #7
jasonojordan
Old 02-27-2017, 12:16 PM   #8
Dakines
yes i did~ attached the file
Old 02-27-2017, 03:07 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, you didn't.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-27-2017, 03:51 PM   #10
Dakines
No, you didn't.
the maf limits is 500g/s ,the engine load limits is 4.did it wrong?
Old 02-27-2017, 04:27 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can see in the photos that your engine load limits 1 and 2 (probably A and B in Romraider) are still stock.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-27-2017, 04:35 PM   #12
steve99
Or error in definition file for his rom calibration ?
Old 02-27-2017, 04:38 PM   #13
steve99
OP
you will need to change 4 limit tables
maf g\s limit to say 500 g\s
overall load limit to say 4
load limit per rpm tables A and B to use higher load limits at rpm
Old 02-27-2017, 05:07 PM   #14
Dakines
i'm sure i did it.
Vishnu OFT Tune Coming Soon for the SBD Turbo Kit! spdbydesign Software Tuning 43 11-21-2018 01:15 PM
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 09:04 PM
FRS/BRZ Turbo Tune teddydoggy Great Lakes 4 09-17-2015 11:17 PM
Greddy Turbo Tune jhusey Forced Induction 2 11-06-2014 12:42 PM
turbo tune dfw bjun Southwest 31 10-22-2014 12:10 PM
