Old 02-24-2017, 06:59 PM   #1
zackegle
Drives: 2013 brz limited
car in limp mode! cel light along with stablity control popped on
so i was just driving my car along the road as usual slightly aggressive and all of a sudden my check engine light popped on along with the stability control off light and now my car is stuck revving between 2-3k rpms and wont go any higher or lower i assume thats just limp mode... luckily i was near an auto shop so i pulled it in there and they scanned it, p2109 was the only code that came up, which they said was tps sensor related.
has this happened to anyone else before? is it common? and how do i get my car out of limp mode so i can drive it to the dealership?
zackegle is offline   Reply With Quote
Old 02-24-2017, 07:38 PM   #2
DAEMANO
Time Traveller
Use just about any bluetooth app (Torque) to clear the code and see if it pops up again. OFTs can also do this.
Old 02-25-2017, 05:51 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'd get it fixed ASAP. That's a safety problem. Sometimes just clearing a code and praying it's OK is fine, but sometimes it'll get you killed if you're pulling out into traffic and it comes back at that very moment. Google that code, there's something wrong
Old 02-25-2017, 06:15 AM   #4
steve99
If you clear the code the dealership or mechanic will have no record of it in ecu.
you can clear it by removing battery terminal and press brake pedal. reconnect battery
this is not a common code.
guybo (02-25-2017)
Old 10-20-2023, 10:36 PM   #5
Loganp98
Drives: White Subaru brz
Hey just checking did you ever get this fixed? My brz is experiencing the same thing
Loganp98 is offline   Reply With Quote
OFT Code U0122.. Limp mode.. Help cameronjones239 Software Tuning 16 05-19-2021 12:25 AM
P0455/P0456 - Will go into limp mode Kojiro Issues | Warranty | Recalls / TSB 23 02-22-2018 10:58 AM
How to limp mode.. vichiball Software Tuning 5 07-12-2016 01:18 PM
Limp mode AFTER clearing CEL white_knight Issues | Warranty | Recalls / TSB 8 03-30-2016 08:40 PM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
