Old 02-24-2017, 10:09 AM   #1
Armin93
Drives: Toyota 86 GTS
Differantial
Hey guys
So i realised that my diff has some backlash.
Which my tuner and mechanic confirmed as well. Its not an urgent problem to fix but replacing the diff would cost around $2000.
I was wondering if anyone knows how to fix the backlash?
Cheers
Armin93 is offline   Reply With Quote
Old 02-24-2017, 10:17 AM   #2
How much is "some"? Some is expected and normal in a RWD system but if excessive then it could be a problem.
Here is some stuff you can look at.
http://www.cusco.co.jp/en/news/toyot...z_rear_di.html
Old 02-24-2017, 10:47 AM   #3
humfrz
Well, like Tcoat said, some backlash is normal.
How many miles on your car .. ??
Do you have any major power mods .. ??
Is it still under warranty .. ??
Do you notice it under normal driving conditions .. ??
Can you notice (hear/feel) a "clunk" when starting off after a gear change .. ??
Come back.
humfrz
Old 02-24-2017, 04:03 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
If it doesn't make noise it's fine.
Old 02-24-2017, 04:18 PM   #5
DAEMANO
Time Traveller
Seconded here. If it's not humming at speed or clunking you're probably ok. Setting up/installing a diff is covered in many videos on YouTube and even a few DIY articles on this site. (video below).
If you're going to fix it yourself and the whole thing is hosed. A used diff + housing and all the rest goes for about $500 on Ebay. It's a direct swap.
If it's just the Ring and pinion/final drive + seals is going to run you about $1400 including labor to fix (unfortunately, I know this first hand).
If you're suspicious about this TAKE IT TO A SPECIALIST or a mechanic that works on differentials all day. Someone that can diagnose it quickly and source parts just as fast. This will likely save you money over a general mechanic who sees a diff 1x month or less.
At 52 seconds they show the backlash being adjusted.
[ame="https://www.youtube.com/watch?v=smbq-vkuIL4"]TOMEI Trax LSD Installation guide by SFR (2 of 3) - YouTube[/ame]
Old 02-24-2017, 04:47 PM   #6
StraightOuttaCanadaEh
Wes
what's backlash?
Old 02-24-2017, 04:56 PM   #7
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Backlash is a political term.
On here, we're not allowed to go there.
ToySub1946 is offline   Reply With Quote
Old 02-24-2017, 06:45 PM   #8
Armin93
The car has about 45 thousand miles on it.
And yes after a gear change i hear a clunk on first, second and sometimes third gear.
The clunk is worse when the car is cold but it almost happens all the time
Old 02-24-2017, 06:59 PM   #9
Ultramaroon
not playing cards
The clunk is worse when the car is cold but it almost happens all the time.
I have it too. Always had it. It's not specifically from the diff but is the sum total of the lash in the whole drive train. Most of that comes from the transmission.
Does your transmission whine at all?
strat61caster (02-24-2017)
Old 02-24-2017, 10:17 PM   #10
stevesnj
stevesnj's Avatar
Yeh no backlash at all in the drivetrain is no good. When 4 wheeling my LandCruiser its needed to prevent binding of the u-joints and pinion gear. When i lock my front and rear diffs no backlash would be bad.
My 2016 Build thread
Old 02-25-2017, 01:01 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Wasn't clunk when engaging in gear more related to our multi-piece drive-shaft? IIRC some reported clunking gone if installed single-pice aftermarket ones.
Old 02-25-2017, 01:07 AM   #12
Ultramaroon
not playing cards
Absolutely not. I remember one person who claimed that but I didn't call bullshit because I didn't want to get into it with him. If there's any lash at all between the transmission and the diff, something is very wrong; dangerously wrong.
humfrz (02-25-2017)
Old 02-25-2017, 03:24 AM   #13
humfrz
I would suggest you drive another twin with a MT for a comparison.
The noise you hear may be normal for the drivetrain.
humfrz
