Old 02-20-2017, 06:59 PM   #1
VVT4ME
VVT4ME's Avatar
Drives: 2014 Scion FR-S
Need info...want to tap power that feeds OEM Bluetooth mic
So...I want to install a couple small led's in the panel that houses the factory Bluetooth mic in the headliner. I saw someone do it, and it looked good....I also drive older BMWs and mine always had small orange ambient led's in the headliner that simply kept the center console dimly lit and made it nice if you had to fumble around at night looking for something you dropped. So.....I want to tap the wires going to the mic. They guy that did it said he just hooked up 'positive and negative'....But I have read that the red and white wires are actually left and right, because it's a stereo mic. (There is also a black wire I have seen in photos). So.......what I want to know is....if I want to tap the mics power, do I tap red and white or red and black? I know the set up works, I saw photos of the finished product lit up. So can anyone help?
VVT4ME is offline   Reply With Quote
Old 02-21-2017, 12:13 AM   #2
darko
Drives: RAVEN FRS
Not sure what circuit you are referring to but usually in this situation you can easily check with a multimeter if red or black is the +12V. For the GND. you can you any bolt on your car as ground (as long as there's no paint)
darko is offline   Reply With Quote
Old 02-21-2017, 01:44 AM   #3
Liquid_Doji
Liquid_Doji's Avatar
Drives: Subaru Brz
You tap using the red line, and use the black to GROUND to something (negative terminal or other metal piece. The white wire is optional and typically used for splicing into other units (not necessary).
I suggest getting a Fuse Tap (aka - add a circuit) and just tap the leds to your fuse box. There are plenty of directions on how to use a fuse tap on youtube but basically you want to tap into a fuse that powers something lower than 10 amps (because your accessory leds typically dont need more than 3). I tapped into either my A/C or audio fuses with a fuse tap and it works flawlessly!
Heres what a fuse tap looks like:
Let me know if you have any other questions
Liquid_Doji is offline   Reply With Quote
BRZ: Bluetooth not showing any track info WarthogBrz Electronics | Audio | NAV | Infotainment 3 03-13-2014 12:45 PM
RSS feeds Tillman32 Site Announcements / Questions / Issues 2 10-10-2013 06:42 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
bluetooth info, no audio? lbroskee Electronics | Audio | NAV | Infotainment 4 07-24-2012 09:22 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
