Old 02-17-2017, 08:22 AM   #1
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Exhaust Hole Cover/ Invidia N1 Fitment
Good morning! I'm new to the forum, and I wanted to start out with this thread. In the very near future, my girlfriend and I will be ordering the Greddy Revolution RS exhaust for my BRZ. I wanted to see what everyone would recommend for an exhaust hole cover. We've been doing a lot of research and have been most impressed with how the Innovated Dynamics exhaust hole cover fills the area. We've looked at what other sites have to offer, and aren't too crazy about the gaps between the cover and the diffuser. We just wanted to see if anyone has had better success with other covers or if there are others out there that we are overlooking.
In addition... Last month, we installed the Invidia N1 exhaust onto my girlfriends FR-S. After the installation, we noticed that the fitment was a little off. More specifically, the left muffler sticks out a tad bit further than the right. We both know with aftermarket parts that the fitment won't be 100% flawless, but we wanted to put it out there to see if anyone else has noticed this with their exhaust and if anyone may have a solution on how to better adjust the exhaust for a better fit. Any guidance would be greatly appreciated!
DaBoBo21 is offline   Reply With Quote
Old 02-17-2017, 08:53 AM   #2
jasonojordan
Drives: 2013 satin white brz limited
On the fitment issue the only real way to see much of a change is either go with some stiffer hangers or bend the hanger rods.
jasonojordan is offline   Reply With Quote
Old 02-17-2017, 08:59 AM   #3
KDad2
KDad2's Avatar
Drives: 2013 Raven
I also have the Invidia N1 and my left exhaust wasn't centered at first no matter what I did. But after some time, it settled into position. I'd recommend waiting before making any major changes. Some spirited driving should shake it into place! Also, I did my install with the Cusco HD hangers.
KDad2 is offline   Reply With Quote
Old 02-17-2017, 10:10 AM   #4
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I think if it comes to it, we'll look at adjusting the hangers a little bit. Thanks Jason.
Old 02-17-2017, 10:11 AM   #5
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Good advice, I'll look into those hangers! Thank you, sir!
Old 02-17-2017, 11:04 AM   #6
KDad2
KDad2's Avatar
Drives: 2013 Raven
No Problem. There are a lot of folks in SA that I'm sure would help you out if needed. You can probably find them here: http://www.ft86club.com/forums/showthread.php?t=106997
Old 02-17-2017, 11:18 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I do a lot of catback installs for locals on a variety of cars, I always use kartboy stiffer hangers on the rear most hangers, and put at least 20-30 miles on cars, being sure to use the full power band and do some at least medium cornering so it settles, heats and cools a few times, and to be sure everything is where it wants to be. The Karboy hangers seem to settle the exhaust faster too, so any adjustments can be made pretty quick.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
jasonojordan (02-17-2017)
Old 02-17-2017, 11:44 AM   #8
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Got it. Thanks, Jazzle. I'll look into those Kartboy hangers, as well.
WTB: Passenger Side Exhaust Hole Cover Nick15Green Canada Classifieds 0 06-26-2016 06:16 PM
PASSENGER SIDE EXHAUST HOLE COVER Ripp91 Exterior Parts (Aero, Lighting, Etc.) 0 04-23-2016 03:29 PM
For Sale - FT86SF exhaust hole cover (right) AREN Canada Classifieds 8 02-06-2016 12:49 PM
WTB Frs Passenger Exhaust Hole Cover OMGArisman Want-To-Buy Requests 0 07-20-2015 12:16 AM
Exhaust hole cover for Single tip exhaust - Innovated Dynamics Kostamojen Cosmetic Modification (Interior/Exterior/Lighting) 4 06-09-2015 10:45 PM
