Old 02-14-2017, 09:03 PM   #1
Fred Flintstone
Drives: 2015 FR-S Asphalt, racing stripes,
Stability
When going faster than I probably should or if there is a strong cross wind I find myself fighting to keep a straight line on a smooth highway. Would like a good stable ride. It feels a little out of control. Don't really need a track car. I understand the stock setup is pretty good but just a more stable feel needed, camber bolts, sway bars what??? Keep it simple. Back in the day owned a 280Z, very stable even at high speed. What's the difference??? I appreciate any help thanks!!!
Fred Flintstone is offline   Reply With Quote
Old 02-14-2017, 09:10 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I had a 240Z. As awesome at it was in the triple digits, the FRS is even better.
Before you go with any mods I suggest you get a good alignment. Get it dead nuts with just a touch of toe in up front. I forget if that's negative or positive. "Almost there" versus "just right" makes a big difference. Factory alignment is a quickie job.
Oh, make sure your tires are all inflated equally. It's really sensitive to even a few PSI out.
strat61caster (02-15-2017), tCsonfrs (02-15-2017)
Old 02-14-2017, 09:41 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
When was the last time you had the car aligned? What are your tire pressures?
The Following User Says Thank You to Pat For This Useful Post:
Racecomp Engineering (02-15-2017)
Old 02-14-2017, 10:18 PM   #4
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
+1 for proper alignment. Your car seems too new to have issues with bushings already, but make sure they check those too when they align the car. (Just in case)
Twinz is offline   Reply With Quote
Old 02-14-2017, 10:50 PM   #5
PeterFRS
PeterFRS's Avatar
Drives: FRS
I think I kind of get where youre coming from..
I religiously get it aligned every season at a perf shop..
BUT
where I'm from winds are really strong off the rockies into the praries (where I am)
and those rare really strong winds days I do feel that the car is "hovering" a little bit when the steering gets a little lighter and wobbles a little bit...
perhaps splitter and rear diffuser might help mitigate that a little better? I have yet to try it out..
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 02-14-2017, 11:09 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
A little toe in for the back (doesn't need to be much at all) and, as mentioned, tire pressure. A proper rear diffuser may help since there's a tiny bit of lift in the back stock, but it shouldn't be needed. With zero toe and enough camber the car follows ruts and uneven crown, I still don't find the car needs work to keep going straight...
The Following User Says Thank You to cjd For This Useful Post:
Ultramaroon (02-15-2017)
Old 02-14-2017, 11:09 PM   #7
fatoni
Caster?
Drive upgrades. Don't buy them.
Old 02-14-2017, 11:22 PM   #8
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Most likely the stock tires. That's the one thing about the stock tires I remember when I ran them, they are good and by no means feel bad, but the car is prone to drift around some at higher speed and in crosswinds. Responsive, stiff sidewalled tire with low rolling resistance compound = tire that effects the chassis some with crosswind influence. Gives the car a somewhat 'floaty' feeling. My car is really stable cruising at interstate speeds with significant crosswinds. The only difference now is I'm running a grippier and smaller diameter tire with much less sidewall stiffness (205/45-17 Continental DW) . The FR-S does not get blown around like it did on the stock tires, and the free CG drop from diameter reduction adds a more stable feeling to the handling.
ALSO, you could try putting some weight in the trunk and see if that helps...like 150lbs or so in the form of packing for a vacation/roadtrip. Car seems to be very stable and impervious to crosswinds when in vacation mode...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-14-2017, 11:35 PM   #9
Ultramaroon
not playing cards
Yeah, what's that all about? :/
Old 02-15-2017, 12:45 AM   #10
Brayden_23
Drives: Asphalt 2015 FRS
Try getting a tad bit of toe in for the front at an alignment shop. Don't buy wider tires as those are prone to "tracking" on the road more. To reduce being floaty at high speeds, front aero would probably help the most if alignment doesn't solve it. Could be a front splitter or you could add the TracSpec hood louvers which supposedly add an insane amount of downforce in the front.
Brayden_23 is offline   Reply With Quote
Old 02-15-2017, 02:04 AM   #11
renfield90
The Stig's German cousin
Guys, we have a lighter car. If the wind is strong enough and you're going fast enough, you *will* get pushed off your intended line. Reduce speed in high crosswinds and you'll be more stable.
The Following User Says Thank You to renfield90 For This Useful Post:
wparsons (02-15-2017)
Old 02-15-2017, 11:47 AM   #12
Gunman
Drives: 2019 Mazda Miata RF
I noticed after I installed the DWL side splitters, that cross winds, and dirty air from large trucks didn't affect the car as much...which is exactly what the side splitter should do, since their intent is to increase downforce in yaw.
Aero, should follow mechanical grip issues though, start with an alignment.
Gunman is offline   Reply With Quote
Old 02-15-2017, 01:14 PM   #13
wparsons
wparsons's Avatar
Check tire pressures, and get a good alignment. 0 toe up or a 1/16" total toe in up front, and 1/16"-1/8" total rear toe in.
Mine tracks dead straight on my summer tires with 0 front toe and 1/16" total in the rear, but on the snow tires in a heavy wind it does get blown around a bit. Front toe in should help, but like someone said above you might just have to reduce speed a bit if it bugs you in heavy crosswinds.
flickr
Old 02-15-2017, 07:19 PM   #14
A good alignment and tire pressures are step one with ANY performance car tuning IMO.
If you haven't done that yet...you need to do that.
- Andrew
Stability Control intervention at very low speed smbstyle Issues | Warranty | Recalls / TSB 10 07-15-2016 02:11 PM
Vehicle Stability Control twostroke BRZ First-Gen (2012+) — General Topics 15 07-13-2014 11:10 AM
Stability Control? ashtray BRZ First-Gen (2012+) — General Topics 27 01-24-2013 05:32 PM
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
