Old 02-12-2017, 01:20 AM   #1
Karl07
Drives: 2012 86 GTS - Storm Black
OpenFlash Manager Connection Issue
I just got an OFT and have Read the Stock File from my 2012 86 GTS.
Unfortunately the Write button was still greyed out so I assume that I need to install the OTS Tunes onto it first.
I went to the OpenFlashTablet website, downloaded the latest version of OFM (ver 1.27) and installed it on my Win7 computer in the default location.
When I have plugged my OFT in using the provided cable, the tablet lights up with the little grey picture of the OFT on the screen, however OFM just sits there throwing an infinite number of "Connecting to Device..." messages.
I have tried reinstalling, using different USB ports, I have tested the cable on other devices, restarting the computer, and tried both USB 2.0 and 3.0 ports.
Oddly enough, the install file is called OFM 1.27, however when I install it says installing OFM 1.0.
Once installed, the program does correctly display Openflash Manager 1.27.0 up the top however...
Any ideas?
Karl07 is offline   Reply With Quote
Old 02-12-2017, 02:08 AM   #2
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
I had a similar issue, it would only connect 1 out of 10 times, turned out the USB cable was faulty.
Vin is offline   Reply With Quote
Old 02-12-2017, 04:40 AM   #3
steve99
as above try a new usb cable they are standard type.
also make sure no other software on you computer is trying to use usb connection like phone apps or similar
Old 02-13-2017, 04:40 AM   #4
Karl07
Turned out it was my computer. I had just reloaded all the drivers and the USB was sending power through but not data.
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
Quick question openflash manager and flash tablet manager Nisien Software Tuning 3 02-28-2016 03:08 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 06:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 10:02 PM
