Northern California NorCal
Old 02-11-2017, 05:57 PM   #1
Cheve
Cheve's Avatar
Drives: 2017 BRZ Premium
Weekend at Tahoe: winter tires?
Hi,
I was asking in the winter tires thread but there is no clear answer there...
What do you people usually run?
I got my BRZ in December and it came with summer tires. I guess that is ok for the Bay Area all year round, but what do you do when you drive to the mountains in winter? Do you have an extra set of winter tires? Are summer ones okay for the weekend from time to time? I have two weeks to make up my mind heh
Thank you!
Cheve is offline   Reply With Quote
Old 02-11-2017, 06:25 PM   #2
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Unless you go there often or drive around the snow a lot, I don't think its worth it to buy winter tires. I'd take the money your spend on wheels and tires and just use it to rent an AWD/4WD SUV for the time you go to the snow.
But to answer your question, my friends in the east coast are big fans of Continental Wintercontacts and Bridgestone Blizzaks
The Following 3 Users Say Thank You to BigFatFlip For This Useful Post:
Cheve (02-12-2017), exE36M3 (02-12-2017), funwheeldrive (02-12-2017)
Old 02-11-2017, 08:51 PM   #3
Eman
Drives: 2013 Scion FR-S 10 series
You could put chains on the rears but I also think you would be better off renting an all-wheel-drive.
Sent from my SM-G920F using Tapatalk
Eman is offline   Reply With Quote
The Following User Says Thank You to Eman For This Useful Post:
Cheve (02-12-2017)
Old 02-11-2017, 09:12 PM   #4
retoocs
With the amount of snow we're getting, there'll probably be chain requirements when you go up since there's a couple more storms coming. You're going to want AWD.
retoocs is offline   Reply With Quote
The Following User Says Thank You to retoocs For This Useful Post:
Cheve (02-12-2017)
Old 02-11-2017, 09:24 PM   #5
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Check out Turo for SUV and Jeep rentals.
TofuJoe is offline   Reply With Quote
The Following User Says Thank You to TofuJoe For This Useful Post:
Cheve (02-12-2017)
Old 02-11-2017, 10:09 PM   #6
Cheve
Cheve's Avatar
Oh, I didn't know that website! I already got a Jeep
Thank you all!
Old 02-11-2017, 11:20 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Cheve View Post
Hi,
Thank you!
Summer tires freeze and could crack let alone act like bricks in terms of grip when you approach freezing themps
Glad you went with Turo
The problem with RWD is chains on the back only gives you grip at the powered wheels to move, not in the front where you steer. Lesson learned from experience
Old 02-12-2017, 10:54 AM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My owners manual says not to use chains because there is not enough clearance. It says another type of device, such as spring chains MAY be used depending on tire size......
I wouldn't put any type of chain on it, too much risk of damage.
Old 02-12-2017, 10:56 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Oh, and to answer your question, I run my dodge 4wd truck when I go to Tahoe.
Cheve (02-12-2017)
Old 02-12-2017, 12:42 PM   #10
finch1750
finch1750's Avatar
^That. I had a fender get destroyed once when my cables broke.
FS: Goodyear UltraGrip Ice WRT 215/45/17 winter tires (tires only) Clawz Wheels and Tires 0 11-04-2016 08:46 PM
My first winter approaching, need some winter tires. Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 01-05-2016 08:56 PM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
Exclusive Private Event for SCION Owners! Weds April 16th Lake Tahoe PMok Northern California 168 04-25-2014 07:45 PM
Hate the Tires I got with my winter tires PoRco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-31-2012 11:49 PM
