Old 02-10-2017, 07:56 AM   #1
westchenx
Drives: Subaru BRZ MY2017
Help! Anyone 23 upshift hard with MT Transmission£¿
I have a MY2017 BRZ and now I have driven it about 8000KM.
I found a problem since 1000km that sometimes it difficult to upshift from 2nd to 3rd gear when the engine coolant and engine oil temp don't reach the normal temperature, especially after cold start. The feeling is like something stuck in the 3rd gear and I feel there is a gear crash at the moment the trans lever was pushed into 3rd gear.
Does anyone also have the same issue? Can it be better if I replace the OEM trans oil with a better one? I think it must be the synchron problem because this issue won't happen if I use double clutch. And after the coolant and engine oil reach normal working temperature, the issue also won't happen and the upshift process will be smooth.
westchenx is offline   Reply With Quote
Old 02-10-2017, 09:34 AM   #2
bababooey
Drives: BRZ SWP Limited -6MT
take it easy on the car first few minutes to warm up. usually its 1 to 2 shift people have trouble with when cold. new car, if that worried take back to dealer to discuss.
Old 02-10-2017, 10:36 AM   #3
Somerandom18
Drives: 2017 manual BRZ
Mine does this too. I've found shifting through all the gears after a cold start a few times helps a lot.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 02-10-2017, 12:58 PM   #4
humfrz
It just takes a few thousands of miles for the transmission to get broken in.
I suggest you just bear with it for a while, especially when it's cold.
You could change the transmission oil ....... but, personally, I think that just might be a waste of time and money.
humfrz
Old 02-10-2017, 03:36 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Upshift quickly but not aggressively. Just do not pause in neutral.
Double clutch downshifts for more comfort but not necessary.
I started noticing a real improvement in the syncros after about 13000 Km. This transmission takes a long time to break in.
Old 02-10-2017, 08:03 PM   #6
westchenx
Yep 12 upshift has the same condition but I searched in the Chinese forum that most people complain 12 shift roughly when vehicle is cold but seldom complain about 23
Old 02-10-2017, 08:05 PM   #7
westchenx
U mean after a cold start, shifting all gears before moving the car will improve the shift feeling when warming up?
Old 02-10-2017, 08:20 PM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
2014, yeah normal.
Packofcrows is offline   Reply With Quote
Old 02-10-2017, 08:38 PM   #9
Somerandom18
Yeah. I do it 2 or 3 times just shifting with the clutch in the whole time. It seems weird but it works for my car anyway.
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
Automatic transmission hard parking engage and disengage nos145 Issues | Warranty | Recalls / TSB 21 09-18-2015 07:30 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Cold transmission hard to shift from 1st to 2nd neutral Scion FR-S / Toyota 86 GT86 General Forum 9 08-08-2012 02:24 PM
