Old 02-09-2017, 02:13 AM   #1
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Question TRD Engine Aluminium Racing Valve Oil Fual Cap Filler Cover
Recently I splashed out on a oil filler cap for a Toyota 86 just to give my engine bay a bit more bling.
I have herd that if you get a cap that is not air tight it will leak oil onto the engine. That makes sense, so has anyone had any experience with this type of mod. What I will make sure is the rubber gasket is big enough and is of the same as the original as I may expect issues.
http://www.ebay.com.au/itm/322139109...%3AMEBIDX%3AIT
FRS2017 is offline   Reply With Quote
Old 02-09-2017, 02:22 AM   #2
swarb
Buy a real one and have no issues. Or simply swap the o-ring from the stock one. You need to make sure the sticker isn't pre-stuck from the factory before you screw it in, so you can apply it after for the perfect alignment. Also take note that it is aluminum and will be too hot to open with the engine warmed up.
Old 02-09-2017, 07:48 AM   #3
FRS2017
Enthusiast 86
FRS2017's Avatar
Thanks, yes this seems like the safest way to do it....I thought of taking the O-ring from the OEM part to the after market version. I am confident that the after market version shouldn't affect the oil quality.
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
Sale or trade Carbon Fiber Engine Cover and HKS Racing Suction Reloaded intake Klaus Jia Engine, Exhaust, Bolt-Ons 10 05-14-2014 07:33 PM
Custom Aluminium Diagonal Braces For Engine Bay Strut Tower Fire Wall NYCsubaruBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 02-04-2014 03:37 AM
Aluminium diagonal braces for engine bay strut tower NYCsubaruBRZ NY / NJ / CT / PA 0 01-27-2014 06:41 AM
FS: Mint Grimmspeed Engine Oil Filler Cap mfbmike Engine, Exhaust, Bolt-Ons 5 12-19-2013 01:15 PM
