Old 02-08-2017, 01:20 PM   #1
EddieZ2
Drives: 2013 FRS
Exclamation Relay click in column when moving from parked
Greetings all. I have a strange problem. 2013 automatic FRS. Here it is... Car is running. When I move the shift lever when parked slightly to the right to move from PARKED, there is an audible click. You can feel the snap in the steering column. I recently had the car in for the ignition lock recall and everything was fine until today. Any ideas ??? Steers fine. It's just when you want to get going that this relay snap occurs.
EddieZ2 is offline   Reply With Quote
Old 02-08-2017, 02:31 PM   #2
humfrz
I'm just guessing (since I don't have an AT) that the sound is coming from the mechanism that unlocks the steering wheel when the car is taken out of park ..... fer sure.
humfrz
Old 02-08-2017, 05:39 PM   #3
EddieZ2
Drives: 2013 FRS
OK..here goes. Put the key in ignition, do nothing, shift lever can be moved to the right but no click. First position on ignition, car not running, move lever to right solenoid fires. Turn on car, car running, steering wheel freely moves...move lever, "CLICK." Now I start feeling around the column and hold onto the ignition key... move the lever, "CLICK." Turn to acc position and move leve "CLICK" and you can really feel it on the key. This was just looked at for the interlock problem on the ignition. Just wondering how normal this is. I can't recall this "CLICK" before . Anybody pull their column apart that can give me an idea as to what this solenoid is doing. It doesn't lock the column that's for sure. ANy help is appreciated. Everything is working it's just one of those things....
Old 02-08-2017, 05:47 PM   #4
The interlock recall was just making sure some wires were plugged so it likely has nothing to do with this. Sure it hasn't always done it and you are just noticing in now since you were looking for something to have changed?
Old 02-08-2017, 05:50 PM   #5
ChimpMania
Drives: 2014 WRB BRZ 6MT
my previous automatic did the same thing...you move the left to the right from park and it would make a clicking noise...i say it's normal
ChimpMania is offline   Reply With Quote
Old 02-08-2017, 06:41 PM   #6
EddieZ2
Drives: 2013 FRS
OK...I'll go with normal. I've been looking at diagrams and they're no real help. Toyota dealer was baffled. Chimp hit it though. Move the lever from left to right in Park...CLICK.
THANKS !
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 01:14 AM
backed into a support column chenshuo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 02-03-2014 08:14 AM
Steering Column Cover Pablitomarrero Cosmetic Modification (Interior/Exterior/Lighting) 6 11-23-2013 11:29 AM
click, clank click sounds when cooling down and more? leaking oil? Boofneenee Issues | Warranty | Recalls / TSB 19 10-02-2013 11:27 AM
WTB: Steering Column Cover (top one) Jamifra Interior Parts (Incl. Lighting) 6 11-27-2012 09:20 AM
