Old 02-04-2017, 09:41 AM   #1
Tim86UK
Drives: Toyota GT86
Retrofitting a 2017 brz limited tachometer?
Hey guys, do you know if this would be possible as a straight swap? I can't stand the old tachometer tbh!
Where would we able to get a part number & price from?
Tim86UK is offline   Reply With Quote
Old 02-05-2017, 12:31 AM   #2
Tim86UK
Drives: Toyota GT86
I can't believe that nobody has replied to this!
Old 02-05-2017, 09:49 AM   #3
extrashaky
Drives: 2014 BRZ Limited
Probably because nobody has tried it yet. You'll need to do it and make a thread on the swap.
Old 02-05-2017, 11:26 AM   #4
You asked a very specialized question on a Saturday morning and are surprised that you didn't get a response in a whole 3 hours?
You can't change just the tach the face is all one unit.
You can however buy all sorts of different faces for the one you have.
http://www.blackcatcustom.com/scion_frs.htm
Old 02-06-2017, 05:25 PM   #5
Viking42
Drives: 2017 BRZ Series.Yellow
You would most likely need to swap the entire cluster since the new BRZ Limited cluster uses a digital screen to display coolant temp and fuel level (among other things). You would also most likely need a 2017+ steering wheel to control the digital display on the new cluster.
'17 BRZ Series.Yellow
'14 Ford F150 4X4
'99 Ford Mustang Cobra
Viking42 is offline   Reply With Quote
Old 02-07-2017, 01:30 AM   #6
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Heheh, AM and PM still mess me up sometimes too :P
But what everyone else said. You'd need to swap the entire cluster, there's already a thread discussing that. No one has done it so far AFAIK.
PandaSPUR is offline   Reply With Quote
Old 02-07-2017, 01:33 PM   #7
halleffect
halleffect's Avatar
Drives: 2016 Subaru BRZ Series.Hyperblue
I'm really interested in this too. Here's the other thread btw: http://www.ft86club.com/forums/showthread.php?t=114910
halleffect is offline   Reply With Quote
Old 02-08-2017, 11:14 PM   #8
GT/86
I LOVE YOUR GT86
GT/86's Avatar
Drives: 2017 BRZ with PP 1982 Datsun210
You better of buying a 2017 BRZ Limited with PP would be the easier way.
GT/86 is offline   Reply With Quote
Old 02-09-2017, 05:02 PM   #9
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
the real question is can the 17 headlights be fitted to the first gen BRZ
spicyricecake is offline   Reply With Quote
Old 02-09-2017, 05:13 PM   #10
halleffect
halleffect's Avatar
There's a thread on that as well: http://www.ft86club.com/forums/showt...89#post2839589
Fitment shouldn't be a problem since other members have installed the 2017 front bumpers on pre-2017 models with the older headlights.
Wiring would be different though since the 2017 headlights have integrated DRLs while the pre-2017 models have DRLs separate from the headlights.
Old 03-22-2017, 05:28 PM   #11
Pyrefyre
Drives: 2013 Subaru BRZ Black
That is the worst way for those of us that have done performance enhancements.
Pyrefyre is offline   Reply With Quote
Old 03-24-2017, 02:15 AM   #12
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
I haven't checked prices, but I assume an entire gauge cluster assembly and steering wheel assembly is going to be at least $2000. Then you have to add the wiring harness for the steering wheel buttons, since the '13-'16 models didn't have any steering wheel controls. Then you have to hope and pray it all works together.
The gauge clusters are coded to the ECU, so you can't just drop in a new one. So you have to go to the dealer to get them to sync them up, which I'm sure isn't a routine operation for them.
It would be a $2000+ gamble to try it. Seems like a lot of effort. It really would be easier to buy a 2017. Most of your mods are going to swap over to the new car.
C4RBON is offline   Reply With Quote
Old 03-25-2017, 02:14 PM   #13
Pyrefyre
Yes the mods CAN swap over. But an entire drive train swap just for a gauge cluster is a little extreme.
"yay a new gauge cluster. Lets see, swap the engine over, trans over, suspension, LSD, brakes...."
Old 03-25-2017, 08:22 PM   #14
ryoma
ryoma's Avatar
if you have a fully modded out car with an entirely different drivetrain than the stock car, a gauge cluster is probably the least of your concerns. also paying all that extra cash to retrofit it would probably not matter if you have already dropped $15k+ into the car. if you have a stock drivetrain, I would actually think the 2017+ would be better since they modified the internals of the engine and a new FD
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
2017 BRZ limited wheels are Not Black. ~el~jefe~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 07-30-2017 12:15 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 Subaru WRX STI, STI Limited, WRX, WRX Limited, WRX Premium mark0006 Other Vehicles & General Automotive Discussions 0 10-27-2016 06:22 PM
