Old 01-25-2017, 07:26 PM   #1
Captain Curt
Drives: 2015 Scion FR-S Base MT
Disabling seat-belt chime - Do airbags still deploy?
I recently ordered a DOT approved street legal harness (Schroth Rallye 3) for both the passenger and driver side. I've heard you can disable the "Seat belt not connected" chime by clicking/unclicking the seatbelt 20 times in 30 seconds. My question is, will the airbags still deploy if I disable this? I searched the forums and Google for a solid hour and can't find out definitively.
Captain Curt is offline   Reply With Quote
Old 01-25-2017, 07:45 PM   #2
ryoma
ryoma's Avatar
I doubt you can turn off the airbags unless you physically disconnect the connectors. the passenger side will have the airbag light for sure so keep an eye on that.
Old 01-26-2017, 12:28 AM   #3
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
There is a discussion on this and i think we concluded that the new system sense the passenger side as a fault in the circuit and cuts it.
umpadupa is offline   Reply With Quote
Old 01-26-2017, 01:18 AM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Airbags dont deploy unless the seatbelt is plugged in whether the chime is dinging or not iirc. Hence why passenger side dash wont deploy without a passenger and the light flashes telling you airbag off if it triggers from something. Driver side might still deploy since it knows the driver is there but since it is part of a safety restraint system meant to work with seat belts I would venture it won't trigger any forward airbag.
Old 01-26-2017, 09:47 AM   #5
It looks like you can disable the alarm without impacting the function but I will let somebody that is better at reading the diagrams confirm or deny that.
http://www.ft86club.com/files/BRZwiringi.pdf
Pages 246-249.
Old 01-26-2017, 12:10 PM   #6
Captain Curt
I think the best way to disable the chime while ensuring airbags deploy would be to just connect the OEM seat belt with a buckle so the circuit completes. Has anyone removed this function of the circuit before and just shorted the pins so the SRS thinks someone has the seat buckled?
Edit: This would be completing the connection H19 - Front Seat Inner Belt Assembly LH on page 248 that Tcoat linked.
The Following User Says Thank You to Captain Curt For This Useful Post:
Tcoat (01-26-2017)
Old 01-27-2017, 01:01 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
No. The best way to turn off the chime is to use carista or techstream to disable it programmatically; the way the feature was designed.
tato.valverde (01-30-2017)
Old 01-27-2017, 10:06 AM   #8
Captain Curt
Is this something that can be done at home? Will a dealer do this, or not due to legal/safety reasons?
Old 01-27-2017, 12:42 PM   #9
Ultramaroon
not playing cards
Carista, I understand, is inexpensive. I can't see why a dealer wouldn't be willing to do it. They'll shut off your DRL for you. They won't throw you in the hoosegow for asking.
Old 01-27-2017, 02:27 PM   #10
The problem I am reading into this is that the chime will be going off since the whole system is disabled with the change in harness. Just turning off the chime will still leave the system disabled. What needs to be explained (I don't know how) is what needs to be done to have the system working so that the chime isn't on.
Does that make any sense at all? Am I way off base in what I read into it?
Old 01-27-2017, 03:58 PM   #11
Ultramaroon
not playing cards
Yes, especially after studying the diagram a little. I'll look much more carefully tonight. Too many question marks at the moment.
Also, I am assuming that, both for safety and to save cost, that the system operates under the assumption that the driver's seat is occupied whenever the car is operated. It makes no sense otherwise.
Old 01-27-2017, 04:03 PM   #12
I assumed the same. Or at least I couldn't see anything that looked like a sensor in the diagram. I only know enough about reading those things to get into trouble though.
Old 01-27-2017, 10:20 PM   #13
MileMonger
MileMonger's Avatar
Has anyone tried these: https://www.japanparts.com/parts/detail/43011
$33 from Japanparts + shipping
I think they might be the solution you're looking for... Maybe. I wonder if there is any redundancy that lets the car know you've got the seatbelt on other than the belt clip, such as sensing if the seatbelt has been tugged suddenly, or at least if it has been been pulled from resting position.
Sent from my SM-G930T using Tapatalk
MileMonger is offline   Reply With Quote
The Following User Says Thank You to MileMonger For This Useful Post:
Tcoat (01-27-2017)
Old 01-27-2017, 10:39 PM   #14
Nothing shown in any drawings and no real reason for hidden or redundant devices so those very well would do the trick. Nice find.
MileMonger (01-28-2017)
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 10:31 AM
Seat belt chime delete?? Anyone track_warrior Cosmetic Modification (Interior/Exterior/Lighting) 29 10-25-2016 03:21 PM
T-boned in intersection, airbags didn't deploy lantsalot Other Vehicles & General Automotive Discussions 28 08-17-2016 07:04 PM
Seat belt chime speaker?? Ryaquinn Cosmetic Modification (Interior/Exterior/Lighting) 3 11-18-2014 02:28 PM
Subaru seat belt chime chitownwrx BRZ First-Gen (2012+) — General Topics 20 05-04-2012 02:35 PM
