Old 01-22-2017, 11:58 PM   #1
hpde_addict
Drives: '18 Camaro V6 1LE
Grinding/vibrating sound going up ramps
I'm lowered around 1.5 inches. Going up ramps diagonally, I hear a grinding/vibrating sound roughly around the time that one of the rear wheels is near the ramp entrance. The traction control light flickers, even with traction control off (5s press, but not pedal dance). I never get this sound going down ramps.
Does this happen to you? Is it just one of the rear wheels losing traction? I'm going to get out my car and inspect once I get a chance to safely do so.
hpde_addict is offline   Reply With Quote
Old 01-23-2017, 01:13 AM   #2
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
You have one rear wheel in the air and the noise is the LSD doing it's thing?
Subsonic is offline   Reply With Quote
Old 01-23-2017, 02:15 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
5s press TC off is not 100% off. As Subsonic mentioned and as was written also in Pedal Dance related threads, in TC off unlike in PD mode you still get electronic brake distribution & TC re-engages if one of wheels completely looses traction/hops in air, trying to restore traction with applying brakes on one side.
Pedal Dance switches off those two aswell, leaving just basic ABS.
Old 01-24-2017, 08:30 PM   #4
zebro racing
Drives: red
I have a similar experience going up my driveway (stock height though). Should I be worried about these noises happening? Keep in mind I am doing this at least once a day everyday.
zebro racing is offline   Reply With Quote
Old 01-24-2017, 09:40 PM   #5
ryoma
ryoma's Avatar
you should worry if the noises stop happening instead. hearing it just means that everything is working as it should.
however, how much of an incline is your driveway? you shouldn't be having a wheel lift in the air unless you're going in at an insane angle that causes a wheel to lift. either that, or you're using too much gas when going up causing the wheel to lose traction
Old 01-24-2017, 09:52 PM   #6
zebro racing
Drives: red
enough of an incline to take it at an angle, but not enough to scrape. it actually sounds more like im unloading the inside rear just enough for it to loose grip and spin. having said all this, i've only had the car for a day or two, so there may be some learning curve, and some new owner jitters from scratching it.
Old 01-24-2017, 10:17 PM   #7
swarb
Sounds like 3 wheeling to me from reduced droop and the lsd(and traction control) fighting the wheel in the air. Try approaching slightly faster and letting the throttle off after your front tires touch the incline and rolling up the incline until the rear wheel drops before accelerating again.
Or less angle/raise car slightly.
Old 01-25-2017, 03:39 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Is electronic nanny engaging brakes on that short occasion big enough issue to do anything at all? They do their job, wear for such short time won't be noticeable .. just ignore it. I get way more often & longer e-diff/vsc kicking in interference when i intentionally get rear out when daily driving, especially in wet & in winter, and even then i don't care about that as increased wear & worse mpg is what i pay for more fun by choice
grinding marbles sound notout86 Scion FR-S / Toyota 86 GT86 General Forum 14 09-08-2016 12:55 PM
Torque dip sound: rattling / vibrating mike_ekim1024 Software Tuning 6 11-06-2013 02:17 PM
Grinding sound under acceleration Therightmike BRZ First-Gen (2012+) — General Topics 9 08-20-2013 02:00 AM
AUTO FRS, GRINDING SOUND COMING FROM UNDERNEATH? Charleswinky Scion FR-S / Toyota 86 GT86 General Forum 12 05-21-2013 08:51 PM
Manual grinding sound deedz Engine, Exhaust, Transmission 22 07-20-2012 10:05 PM
