Old 01-22-2017, 09:59 PM   #1
RJasonKlein
RJasonKlein's Avatar
Square Set Up with Different Offsets Front and Rear?
Looking at the sticky wheel fitment guide, you need about 10mm more 'poke' in the rear than the front with a square set up to have a perfectly flush fit at both ends of the car. Does anyone ever run a square set up with different offsets front and rear to achieve this? Obviously, this isn't very practical because it prevents rotating the tires without pulling them off of the wheels and remounting them, but how else can you achieve a perfectly flush fit at both ends of the car?
In my case, I run a square set up with the same offset front and rear and have just lived with the rear wheels being tucked in further than I would have like - I'm just wondering if anyone has done what I'm asking in the pursuit of perfection?
RJasonKlein is offline   Reply With Quote
Old 01-22-2017, 10:07 PM   #2
gramicci101
Off Topic
There's no reason you couldn't do it. Especially with Enkei, since they tend to come in +45 and +35 offsets for the same wheel. It does limit your wheel choices though.
The Following User Says Thank You to gramicci101 For This Useful Post:
RJasonKlein (01-22-2017)
Old 01-24-2017, 12:58 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Same spec wheels and just get extended studs and slap spacers on the rear. Still able rotate while getting the look you want.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
RJasonKlein (01-24-2017), strat61caster (01-24-2017)
difference in offsets jdmblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-05-2014 05:18 PM
SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear Amalgamo Brakes, Suspension, Chassis 3 04-24-2014 07:22 AM
Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around??? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 02-20-2014 03:50 AM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
Square Setup w/ Rear Spacers thejevans Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-11-2013 04:53 PM
