Old 01-14-2017, 10:56 PM   #1
MyGT86Yas
Drives: 2017 WRB BRZ
What is that noise
My 2-month-old 86 has been making some noise consistently from the engine bay area. I suspect it was a clutch problem but both the dealership technician and foreman couldn't seem to locate the problem. Hopefully can get some ideas here before I drop my car in next time.
Here is the syndrome:
1.)The car only makes the noise when the car is fully warmed up, no noise when cold start.
2.)The noise is like one metal piece tapping on another metal piece.
3.)It occurs when casually accelerate from a full-stop at 1st gear. The moment when I release the clutch and accelerate.
4.)When rolling in 2nd gear and accelerate after(Like rolling into a corner and accelerate after the conrer, at around 18mph)
5.)Sometimes I can feel the collision from the shifter when shifting into 1st gear.
Any help will be much appreciate, really try to keep my baby babied.
MyGT86Yas is offline   Reply With Quote
Old 01-14-2017, 11:03 PM   #2
phrosty
maybe take a video?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 01-14-2017, 11:25 PM   #3
MyGT86Yas
Went out to drive it abit but no noise. Will try to record it later tonight.
Old 01-15-2017, 09:51 AM   #4
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Our cars have noisy transmissions and engines from the start. Between my clutch and the DI system youd think its coming apart compared to other vehicles. The best thing is to find a friend with a frs/brz/86 with some miles already on it and see whay your hearing is normal.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-15-2017, 08:34 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
At what kind or RPM is this happening? My experience is that our engines don't like to be lugged at low RPMs and below 2k can make some weird rattles.
1974 TA22 Celica
2013 86 GT
Old 01-15-2017, 08:40 PM   #6
MyGT86Yas
Yeah it only happened at low rpm. So maybe it's normal for our car? Should I try to flush the transmission fluid?
Sent from my Nexus 6P using Tapatalk
Old 01-15-2017, 08:40 PM   #7
Teseo
Drives: frs
Mine did something like that. Ended with TOB and fork out of spec, replaced clutch disk and all sounds went off
Old 01-16-2017, 03:06 AM   #8
humfrz
I think that would be a waste of time and money.
I'd suggest you bang/look around underneath your car after it is warmed up, to see if you can find something (like a heat shield) that is lose.
Like mentioned, don't lug the engine ...... it ain't your grandpa's old flathead Ford .....
humfrz
Old 01-16-2017, 10:12 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1 to @Turdinator. Just don't lug it. Perfectly normal.
High compression 4-banger + relatively light (for OEM) flywheel = gearbox rattle.
Old 01-16-2017, 10:24 PM   #10
MyGT86Yas
I don't think it was my driving. The shop foreman and I went for a drive and he didn't say a thing about my driving, and he confirmed there was a weird noise from the engine area.
Old 01-16-2017, 10:46 PM   #11
Ultramaroon
not playing cards
Get a decent recording and post it up.
Old 01-17-2017, 12:03 AM   #12
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Is it clutch chatter? Do you have an aftermarket clutch?
Edit: Completely misread the OP post....I thought it said 2 month old E85.....
Alltezza is offline   Reply With Quote
Old 01-17-2017, 12:06 AM   #13
MyGT86Yas
No, my car is stock except catback and springs.....I will try to record a video tomorrow.
Old 01-17-2017, 01:03 AM   #14
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
if I had to take a wild guess without hearing anything I would say throw out bearing. For some reason these cars do absolutely wonky things that would be out of the normal with any other platform. But then again.....
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
What's this noise? Nitesh31 Issues | Warranty | Recalls / TSB 3 12-19-2012 09:35 PM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 05:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 03:21 PM
