Old 01-09-2017, 07:08 PM   #1
cowdog360
Drives: 2014 BRZ Limited
Exhaust questions - 1 side more dirty than other?
Hey all,
I bought a used magnaflow setup for my BRZ last year. What I've notices is that the right outlet tip is always way dirtier than the other, and the metal seems to discolor at a faster rate.. like the exhaust gases are favoring that side more than the other. Anyone else have this issue? Suggestions?
cowdog360 is offline   Reply With Quote
Old 01-09-2017, 07:15 PM   #2
scottman
scottman's Avatar
Drives: 13 mt fr-s
Just punch it more often, and they will discolor at the same rate.
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
wbradley (01-09-2017)
Old 01-09-2017, 07:38 PM   #3
anodic
Drives: Halo frs
Either clean them more often or just leave it alone.
Great solution no matter how lazy or motivated you are.
anodic is offline   Reply With Quote
Old 01-09-2017, 08:27 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
OEM exhaust does that too. Exhaust path is taking the path of least resistance.
Gunman is offline   Reply With Quote
Old 01-09-2017, 08:30 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Don't clean the carbon inside the tips. It looks mean.
Clean the outside of the tips though.
The Following User Says Thank You to wbradley For This Useful Post:
Teseo (01-09-2017)
Old 01-09-2017, 09:15 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It isn't a true dual exhaust so the gases take the path of least resistance mentioned making one side see more gas then the other making it more dirty
Old 01-10-2017, 10:59 AM   #7
humfrz
[QUOTE=cowdog360;2828571]Hey all,
I bought a used magnaflow setup for my BRZ last year. What I've notices is that the right outlet tip is always way dirtier than the other, and the metal seems to discolor at a faster rate.. like the exhaust gases are favoring that side more than the other. Anyone else have this issue? Suggestions?[/QUOTE]
Yep, Bubba says to spray paint the inside of the tail pipes with a hi-temp flat black paint .........then you won't notice the difference ......
humfrz
Old 01-10-2017, 01:54 PM   #8
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
On a positive note one side will be cleaner than the other.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
shellslinger (01-10-2017)
Old 01-10-2017, 03:55 PM   #9
shellslinger
Drives: Whiteout FRS
The silver lining LOL
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
Scrappydoo (01-10-2017)
Old 01-10-2017, 05:19 PM   #10
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
The slightly less black lining
Exhaust Set-Up Questions Anderzz Engine, Exhaust, Transmission 5 08-26-2016 03:17 PM
Exhaust Questions! Bjeoen Engine, Exhaust, Transmission 3 12-02-2015 12:21 AM
How to clean a dirty catback exhaust? JS + BRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 03-18-2014 06:05 PM
Exhaust Questions? 636 Engine, Exhaust, Transmission 6 10-19-2013 04:14 PM
Chargedspeed Side skirt questions. grostoine Cosmetic Modification (Interior/Exterior/Lighting) 4 10-15-2013 01:05 AM
