| Engine Swaps Discussion of engine swaps. |
Drives: Left the fourms
Will a four rotor fit?
Would a 4 rotor fit in a BRZ/GT86?
Just curious since a four rotor is long and the FA20 is wide but both are about 2000cc in size. Thank you |
The Gunshine State
Drives: '14 BRZ Limited
Anything can fit with enough money.
If they can fit a 4 rotor in a Miata they can in a twin.
![]() Current DD: M235i |
Haha. I guess so!
/scion
Drives: '13 86 M/T
Yes.
"Practice makes better. Only Senna is perfect." - CSG Mike
I just realized I got my numbers wrong. 4 rotor is 2600cc
Doesn't matter what the displacement is since it has very little to do with the exterior size of the block in the long run.
Drives: 2015 Subaru BRZ WRB
Yes it will fit.
Technically no the 4 rotor is not 2000cc... . its a 2616cc according to common measures. It's really a 7.8Ltr, that is if you count each side of the rotor as its on compression chamber. |
Yea I was thinking of a 3 rotor
#9 | |
Drives: red frs
4 rotor is twice as long as typical 13b because you have to stack housings and irons. also as far as fit it will be tight. length wise. |
#10 |
Yes. What I meant was that it doesn't matter if the 4 rotor was 2,000 or 2,600cc the block would be about the same size.
#11 | |
Drives: red frs
the 20b would fit, 26b will be really tight to the radiator. the spacing on my 13b is close to stock distance from radiator. |
#12 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'd really like to see a rotary motor in these cars.
#13 |
Drives: red frs
#14 |
| Pad Rotor Problem AP Disks | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 04-18-2022 12:53 AM |
| Blue Rotor Rings | Stang70Fastback | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-07-2016 10:13 AM |
| Rotor replacements | cab33 | Tracking / Autocross / HPDE / Drifting | 8 | 11-04-2015 05:04 PM |
| Rotor Weight | ender2664 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 05-14-2013 05:14 AM |
| Has anyone cracked the OEM rotor yet? | ayau | Tracking / Autocross / HPDE / Drifting | 10 | 04-22-2013 04:41 PM |
