Old 01-06-2017, 11:16 AM   #1
AgentNH
Drives: Left the fourms
Will a four rotor fit?
Would a 4 rotor fit in a BRZ/GT86?
Just curious since a four rotor is long and the FA20 is wide but both are about 2000cc in size.
Thank you
AgentNH is offline   Reply With Quote
Old 01-06-2017, 11:20 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Anything can fit with enough money.
If they can fit a 4 rotor in a Miata they can in a twin.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-06-2017, 11:23 AM   #3
AgentNH
Haha. I guess so!
Old 01-06-2017, 11:29 AM   #4
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Yes.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 01-06-2017, 11:41 AM   #5
AgentNH
I just realized I got my numbers wrong. 4 rotor is 2600cc
Old 01-06-2017, 12:13 PM   #6
Doesn't matter what the displacement is since it has very little to do with the exterior size of the block in the long run.
Old 01-06-2017, 12:41 PM   #7
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Yes it will fit.
Technically no the 4 rotor is not 2000cc... . its a 2616cc according to common measures.
It's really a 7.8Ltr, that is if you count each side of the rotor as its on compression chamber.
irax is offline   Reply With Quote
Old 01-06-2017, 01:33 PM   #8
AgentNH
Yea I was thinking of a 3 rotor
Old 03-05-2017, 11:29 AM   #9
Shit Luck
Drives: red frs
that is not true with a rotary..
4 rotor is twice as long as typical 13b because you have to stack housings and irons.
also as far as fit it will be tight. length wise.
Shit Luck is offline   Reply With Quote
Old 03-05-2017, 11:44 AM   #10
Yes. What I meant was that it doesn't matter if the 4 rotor was 2,000 or 2,600cc the block would be about the same size.
Old 03-05-2017, 11:46 AM   #11
Shit Luck
Drives: red frs
yeah that's true.. you don't get much option on displacement with a rotor motor.
the 20b would fit, 26b will be really tight to the radiator. the spacing on my 13b is close to stock distance from radiator.
Old 03-05-2017, 12:32 PM   #12
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'd really like to see a rotary motor in these cars.
MS, CSCS, TSAC-F, CPT
Old 03-05-2017, 12:59 PM   #13
Shit Luck
Drives: red frs
Soon...
Old 03-05-2017, 01:04 PM   #14
weederr33
weederr33's Avatar
Soon...
Pad Rotor Problem AP Disks Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 04-18-2022 12:53 AM
Blue Rotor Rings Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-07-2016 10:13 AM
Rotor replacements cab33 Tracking / Autocross / HPDE / Drifting 8 11-04-2015 05:04 PM
Rotor Weight ender2664 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-14-2013 05:14 AM
Has anyone cracked the OEM rotor yet? ayau Tracking / Autocross / HPDE / Drifting 10 04-22-2013 04:41 PM
