Drives: scion frs
AFR Monitoring under WOT
Have a scan gauge hooked up - appears that the OB-2 output is not calibrated to read below 12.0. I would like to monitor how the AFR varies under richer / WOT conditions. I'm assuming I need an o2 sensor
upgrade ? or not ? Any recommendations ... Thanks. |
Any particular reason why you want to monitor AFR on a stock (I'm assuming) car?
Drives: 2013 Scion Frs 6mt
Go ecutek playa
Drives: scion frs
D_T - the Car will not be stock for long. Thinking of the OFH & maybe E85 so would like to baseline performance.
Drives: '13 BRZ
Most tunes will rescale the factory O2 sensor so that it reads richer AFR more accurately. It is still not perfect, so it is best to install and reference an aftermarket wideband.
Drives: scion frs
thanks BRZ - I will see if anything changes after an OFT tune- any recommendations as far as aftermarket wideband sensors go ?
#7 | |
Drives: UK GT86
.: Stealth 86 :.
#8 | |
| Best/Preferred gauges for monitoring. | gdrider77 | Forced Induction | 84 | 11-24-2015 04:35 AM |
| **Rev Works Engine Monitoring Sale** | Rev Works | Audio/Visual, Electronics, Infotainment, NAV | 17 | 04-10-2015 01:50 PM |
| Data Log or Monitoring | exam2300 | Software Tuning | 10 | 03-22-2014 09:35 PM |
| Gauges - The best in monitoring devices! | Rev Works | Interior Parts (Incl. Lighting) | 1 | 07-28-2013 09:28 AM |
| New Tire Pressure Monitoring Sensors? | Kochinopride | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 04-14-2013 08:51 PM |
