Old 03-18-2014, 02:24 PM   #1
exam2300
Data Log or Monitoring
All,
Please excuse the lack of knowledge or proper term, but I am searching for a software to be able to monitor and data log my drive. I am curious if ecutek can perform this task. If so, which software do I need from ecutek. And if ecutek cna not do the job, which software and part will I need?
I truly appreciate the feedback.
Regards,
exam2300
exam2300 is offline   Reply With Quote
Old 03-18-2014, 02:39 PM   #2
wparsons
wparsons's Avatar
Do you want to just log things, or do you also want to flash a new tune to the ECU?
No offense, but if you don't know the proper terminology or know what you're after, then you probably don't need the data you're after.
What kind of data do you want, and what do you want to do with it?
flickr
Old 03-18-2014, 02:42 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you merely want to datalog the OBDII port channels, then there are much cheaper solutions than an EcuTek license and cable.
Old 03-18-2014, 02:47 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
Get a ELM327 bluetooth module on ebay and the "torque app" for Droid.
Play with that and see if it is all you need. If not, you are only out ~$15
Old 03-18-2014, 03:06 PM   #5
exam2300
The reason why i suggested Ecutek cause i have the license and cable already thru my JR-SC upgrade.
And no offense at all... I get it...
Since I am not firmuliar with Ecutek, what software can I use from them? And do I have to pay extra?
Old 03-18-2014, 03:38 PM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You have all you need. Just need to install the software in your computer and log away...
@jamesm would have responded to this in no time...
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Luckrider (03-18-2014), wparsons (03-18-2014)
Old 03-18-2014, 03:49 PM   #7
exam2300
Thank Lastly...
But which Module from ecuteck do I need to download and use?
Old 03-18-2014, 03:55 PM   #8
Sportsguy83
Drives: Limited BRZ
You download Ecutek app downloader, and that will download to your computer all you need.
http://www.ecutek.com/Support/Downloads.aspx
Old 03-22-2014, 10:21 PM   #9
mashal
DADA
mashal's Avatar
Drives: 2013
Jr should give you all this info, there are PDF files that point out step on how to donlpad and use ecutek
mashal is offline   Reply With Quote
Old 03-22-2014, 10:28 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
How do you log with torque? I only see the real time data. I'm going to a track day and would like to see my oil temps after.
Old 03-22-2014, 10:35 PM   #11
stugray
While viewing realtime data, there is a settings button (a gear).
clicl lthat and you can select "start logging".
If you dont have that option, maybe you need the pro version $5
The Following User Says Thank You to stugray For This Useful Post:
ZionsWrath (03-22-2014)
Best/Preferred gauges for monitoring. gdrider77 Forced Induction 84 11-24-2015 05:35 AM
Free credit monitoring from Target torqdork Off-Topic Lounge [WARNING: NO POLITICS] 0 01-14-2014 03:11 PM
Gauges - The best in monitoring devices! Rev Works Interior Parts (Incl. Lighting) 1 07-28-2013 10:28 AM
Tyre Pressure Monitoring Systems Fish Eagle AFRICA 3 07-14-2013 05:52 PM
New Tire Pressure Monitoring Sensors? Kochinopride Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-14-2013 09:51 PM
