Old 12-13-2016, 11:45 PM   #1
zman
zman's Avatar
Drives: scion frs
Taillight problem.
1 year ago I cut open my Taillights and painted them. One week ago it rained heavily and some condensation got inside. Now the taillight has some weird foggy line. It looks like condensation but it's not. Any way I can clean this without having it to reopen?
zman is offline   Reply With Quote
Old 12-14-2016, 12:30 AM   #2
humfrz
Originally Posted by zman View Post
1 year ago I cut open my Taillights and painted them. One week ago it rained heavily and some condensation got inside. Now the taillight has some weird foggy line. It looks like condensation but it's not. Any way I can clean this without having it to reopen? ...........
Well, now, the bolded part gets you a humfrz ....
What led you to the conclusion it's not condensation ... ??
Betch ya it is moisture ....
My second guess is that the glue you used, is causing the lens to fog where it came in contact with it.
I'd suggest you heat up the area with a hairdryer to see if the "foggy" line moves (disappears).
Come back.
humfrz
Old 12-14-2016, 10:15 AM   #3
zman
zman's Avatar
Drives: scion frs
Come back.
humfrz
Im for sure it's not condensation , it looks different but similar. I waxed the car before this happened, possible it's wax?
I will give the hairdryer thing a try later.
Old 12-14-2016, 11:26 AM   #4
humfrz
If it's on the outside, I'd suggest you scrub it down with some Dawn soapy water and a tooth brush ....... see if it goes away........
humfrz
zman (12-14-2016)
Old 12-14-2016, 11:29 AM   #5
FX86
just don't wash the car and then when it's dirty it will blend in with your tail lights fog
The Following User Says Thank You to FX86 For This Useful Post:
zman (12-14-2016)
Old 12-14-2016, 01:32 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Either it's on the outside and you can run it off (use some extra elbow grease or maybe even a buffer to make certain) or you can't and it's on the inside meaning you need to cut them open again probably.
Old 12-14-2016, 04:31 PM   #7
zman
zman's Avatar
Drives: scion frs
Unfortunately it's on the inside, guess I'm just gonna have to deal with it
Old 12-16-2016, 02:26 AM   #8
maui86
Drives: 86
Not quite sure how far past the edge/curve the cloudiness extends, but you might be able to get away with a well cut piece of opaque vinyl covering the top of the lens and the clouded part?
maui86 is offline   Reply With Quote
The Following User Says Thank You to maui86 For This Useful Post:
zman (12-17-2016)
Old 12-28-2016, 04:27 PM   #9
maui86
Drives: 86
Just came across this taillight cover from Downforce as well:
http://www.ft86club.com/forums/showp...73&postcount=1
Old 12-28-2016, 04:59 PM   #10
wbradley
Sarcastic SOB
wbradley's Avatar
You might be able to get some long Q Tips (I get them at an electronics supply), and clean theough the bulb pass thru
Or, you can tape a Q Tip to a pencil. Also, it might help to put a piece of cloth or paper towel on the end of the QTip and push it around the dirty area.
The Following User Says Thank You to wbradley For This Useful Post:
zman (12-29-2016)
wtb: tom's taillight FRSure Exterior Parts (Aero, Lighting, Etc.) 3 07-19-2014 03:33 PM
FS: FRS taillight JDM TYPEONE86 Exterior Parts (Aero, Lighting, Etc.) 0 02-09-2014 02:50 AM
Taillight giveaway CharlieChaos New England 0 07-17-2013 05:03 PM
Tom's vs. Valenti's Taillight GH05T Cosmetic Modification (Interior/Exterior/Lighting) 10 07-14-2013 11:26 PM
Red Taillight JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 11-18-2012 04:05 PM
