Old 12-13-2016, 02:40 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
TPMS Reset Button?
Was driving 80 miles 2 days ago on the freeway when my TPMS Light came on. I pulled over and checked the pressures and there were all fine.
Went home and let it sit, checked it when it was cold and again it was fine. It's still staying on though. Looked at the owner's manual and it's a faulty sensor. Since it blinks a few times then becomes solid.
I've searched around and some of the Toyota + Scion models have a TPMS switch to reset it (either under the steering wheel or on the left side where the trunk release is).
Is there any switch for this car? Or do I have to take it to the dealer? They're aftermarket wheels that I had a shop transfer the stock TPMS sensors over so I'm afraid they might charge me an arm and leg for it.
Clueless
YamahaR86 is offline   Reply With Quote
Old 12-13-2016, 03:07 PM   #2
Tokay444
By fine, were they all within two psi of each other?
Old 12-13-2016, 03:12 PM   #3
stevesnj
stevesnj's Avatar
Uh Oh. Could be a damaged sensor during the wheel swap. Toyota can diagnose it but may not cover it's replacement.
My 2016 Build thread
Old 12-13-2016, 03:33 PM   #4
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Yeah, they were 38 Hot and 35 Cold.
I've had the wheels swapped for a year now and it's been fine but all of a sudden it started acting up.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post:
stevesnj (12-13-2016)
reset TPMS? 86to86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-24-2015 01:32 AM
TPMS reset charge FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-09-2014 01:22 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
Miami dealer for TPMS reset yomny Southeast 3 10-09-2012 11:17 AM
