Old 12-09-2016, 07:11 AM   #1
kuangxtc
Drives: 2013 DGM BRZ Limited
ST Suspensions Sporttech Springs
Hey guys, I've searched ft86 forums and google, but 'ST' just won't show up in the search results, it's too short. With that said, does anyone have any experience with these lowering springs? They're made by ST, so I'm sure they're really good for the money. I'm searching for a spring that will work well with the stock struts and not blow them out prematurely, similar to how the RCE Yellow Springs are built for oem struts but the ST's are less expensive.
http://www.ft86speedfactory.com/st-s...rings-872.html
kuangxtc is offline   Reply With Quote
Old 12-09-2016, 09:59 AM   #2
Tor
Tor's Avatar
Drives: Toyota GT86
I have no first hand knowledge just trying to help you out.
They have German TÜV which means they are street legal in Germany. Documentation is required for that:
http://docs.kwsuspension.de/ga56045-1201-12.pdf
From the documentation, it says they have a progressive spring rate and uses the stock bump stops.
Given that they are street legal and the authorities here are pretty rigorous they probably won't blow your shocks. If they work well is another matter...
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
Teseo (12-10-2016)
Old 12-09-2016, 11:06 AM   #3
wparsons
wparsons's Avatar
What are you hoping to get out of the springs?
flickr
Old 12-09-2016, 02:57 PM   #4
kuangxtc
"I have no first hand knowledge just trying to help you out.
Given that they are street legal and the authorities here are pretty rigorous they probably won't blow your shocks. If they work well is another matter... "
Thanks for the info!
I only daily drive the car and want to minimize the wheel gap, but I wan't to keep the oem struts. I'm looking for a spring that was designed to be used with the oem struts and won't blow them out after a couple thousand miles. I did some research and the RCE yellows meet my criteria, but I can get the ST springs considerably cheaper (~$170 cheaper) so if they are high quality and lower my car without blowing out the struts, I'd be really happy.
Old 12-09-2016, 03:10 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
IMO, save up for the RCE Yellows.
Originally Posted by humfrz
I'm old and lazy
Teseo (12-10-2016)
Old 12-09-2016, 04:12 PM   #6
wparsons
wparsons's Avatar
If you're not really pushing the car at all, and don't care what the handling balance (from spring rates) is like, then these should be fine. I'd personally go with the RCE Yellows or Swift Sport (I have swift sport FRS rates).
As for the costs... the ST's are only ~$70 cheaper, not $170. ($232 vs $299)
http://www.ft86speedfactory.com/race...rings-475.html
flickr
Old 12-09-2016, 04:48 PM   #7
8R6
8R6's Avatar
Drives: FRS
Hotchkis springs are awesome for the money too and work well with the stock shocks
8R6 is offline   Reply With Quote
Old 12-09-2016, 05:26 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Another vote for RCE yellows. I have no first hand knowledge of the ST springs but the Yellows are worth it.
Racecomp Engineering (12-09-2016)
Old 12-09-2016, 06:31 PM   #9
kuangxtc
The only reason I'm considering is because of how well recieved their coilovers are and there's open box, but brand new set of ST springs I can get for $130.
I'll try to do some more research but the overwhelming consensus of ft86 is RCE's
Thanks!
Old 12-09-2016, 06:52 PM   #10
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Doesn't look like they publish the spring rates. If the rates are good I'd be all over them for $130 for a new set. While ST is a reputable brand, I'd be a bit wary of suspension manufactures that don't disclose the specifics like spring rates. I suppose you can ask the customer service, but how can you be sure short of testing it yourself?
http://www.stsuspensions.com/st-susp...brz-65820.html
Intent > Content
Old 12-09-2016, 07:05 PM   #11
kuangxtc
Just called KW and they said the springs are progressive and don't have a rate and blatantly said these springs would be bad for OEM struts. Looks like I'm going with RCE's baby!
Old 12-09-2016, 07:34 PM   #12
solidONE
solidONE's Avatar
Progressive springs also have spring rates. Take these Eibachs, for instance.
Spring Rate Front: 148-200-371lbs/in (Progressive)
Spring Rate Rear: 103-274-388lbs/in (Progressive)
https://www.rallysportdirect.com/par...wering-springs
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
cdrazic93 (12-12-2016)
Old 12-10-2016, 01:29 AM   #13
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Was going to suggest maybe looking at Eibach Pro kit. The TRD springs are literally just rebadged versions of the pro kits so they shouldn't cause any issues with premature wear on stock struts.
Stats pulled directly from another thread:
Product: Eibach Pro-Kit Lowering Springs
Front: claimed 1.0" vs actual 7/8" (rate: 3.6kg/mm)
Rear: claimed 1.0" vs actual 7/8" (rate: 4.9kg/mm)
Part No: 8210.5.140
MSRP: $359
Lynxis is offline   Reply With Quote
Old 12-10-2016, 01:38 AM   #14
D_Thissen
D_Thissen's Avatar
The Following User Says Thank You to D_Thissen For This Useful Post:
Racecomp Engineering (12-10-2016)
WTT: 2015 WRB sporttech trunk Buddha_9 Canada Classifieds 2 11-27-2016 06:02 PM
Trunk trade WRB - My Sporttech for your basic ! Simon99 CANADA 1 01-20-2015 09:56 PM
BRZ limited/sporttech seats harkbrz Canada Classifieds 0 11-09-2014 01:22 PM
Difference between sporttech and 10 series? Muskokan BRZ First-Gen (2012+) — General Topics 22 10-02-2013 12:52 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-24-2013 12:42 AM
