Old 12-07-2016, 07:17 PM   #1
Kerrija
Drives: 2016 Subaru BRZ Limited
Reverse light flickering when car is on.
When I turn on my car the reverse lights on my Valenti 4th light flicker I've checked the connections and everything seems okay when the car is off. When I turn on the engine the reverse lights flicker. Any idea what could be causing this?
Kerrija is offline   Reply With Quote
Old 12-07-2016, 07:21 PM   #2
ryoma
ryoma's Avatar
Sounds like a connection problem to me. Do you have a separate ground for the light? Is the reverse light flickering without the car in reverse? Try unplugging and replugging the connector
Sent from my VS986 using Tapatalk
Old 12-07-2016, 07:39 PM   #3
Kerrija
Yeah the light is flickering when it's just in neutral. I've unplugged and re-plugged it back in and made sure it's snug. It's just using the regular connection for the reverse light and it's hooked up to the tail for the running light and brake but those aren't causing the problem as I've disconnected that tail light and it still flickers. If I disconnect the reverse plug it'll go off but leave me with no light at all.
Old 12-07-2016, 07:56 PM   #4
Kerrija
Never mind I figured it out. Apparently switching to LED made it think the light bulb was out due to the lower resistance. Adding in a resister fixed the problem.
The Following User Says Thank You to Kerrija For This Useful Post:
FX86 (12-09-2016)
Old 12-09-2016, 11:07 AM   #5
FX86
very good you replied back with a fix
always hate when people fix it but never let others know what the resolution was
Old 12-09-2016, 11:39 PM   #6
Kerrija
Yep, can't leave ya hanging. Also the lights look freakin amazing now that everything works!
2013 BRZ Reverse Light (Reverse & Reflector) kberkel Exterior Parts (Aero, Lighting, Etc.) 0 08-14-2016 01:14 AM
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly zeal86 Exterior Parts (Aero, Lighting, Etc.) 15 05-29-2016 10:01 PM
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 10:25 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
