Old 12-06-2016, 10:46 PM   #1
Ravensbro
Ravensbro's Avatar
Drives: 2016 Suabru BRZ Charcoal Gray
Reflector Delete
I have been looking around to see if I can find a way to get rid of that annoying low reflector. I like the look of the smoked out 4th brake light but don't want to deal with wiring and don't really want a light there. Is there anything to achieve the same look without buying a 4th light unit and just not wiring it?
Ravensbro is offline   Reply With Quote
Old 12-06-2016, 11:22 PM   #2
ryoma
ryoma's Avatar
your reverse lights are down there so you probably don't want to remove it. you could always "smoke" the red triangle part to make it seem more hidden (tape off the reverse light sections and hit it with that smoke effect spraycan thing). I am not sure how well it would look though...
Old 12-06-2016, 11:48 PM   #3
Ravensbro
Ravensbro's Avatar
I know the 4th brake light installs have reverse lights still but I don't want to spend all that to put it in and not use the light itself.
Old 12-07-2016, 02:35 AM   #4
ryoma
ryoma's Avatar
wait... I am not understanding you. the reverse lights are next to the red triangle OEM, so you are not buying anything to have reverse lights. you can replace it if you want a working 4th brake light, or modify it and insert a bulb into the red triangle to light it up. the reverse lights and the red triangle are all one piece so you can't remove one by itself.
Old 12-07-2016, 03:04 AM   #5
Ravensbro
Ravensbro's Avatar
I want something like this but I don't care for the brake light portion to work
http://www.ft86speedfactory.com/gcs-...l#.WEe0K7IrKM9
Basically just want the area blacked out but still have reverse lights.
Old 12-07-2016, 03:05 AM   #6
Ravensbro
Ravensbro's Avatar
Make it look similar to http://www.ft86club.com/forums/showthread.php?p=2254080
I just hate the reflector and just don't care to have another brake light or even wire it
Old 12-07-2016, 03:50 AM   #7
ryoma
ryoma's Avatar
you can use something like this since it is cheap and reversible if you don't like it:
https://www.amazon.com/Inches-Adhesi...GS0W2CNXKFV96N
I would recommend vinyl if you want to have a smoked effect since it is reversible compared to rattle can. only downside is that if you smoke the whole thing the reverse lights might not work that well
Old 12-07-2016, 03:55 AM   #8
Ravensbro
Ravensbro's Avatar
I'll think on that. Was just hoping someone knew of a part I could switch it out to that was plug and play to get rid of that annoying reflector.
Sent from my SM-G930R4 using Tapatalk
Old 12-07-2016, 06:54 AM   #9
Stang70Fastback (12-07-2016)
Old 12-07-2016, 07:21 AM   #10
Gunman
Drives: 2019 Mazda Miata RF
Paint it black.
Gunman is offline   Reply With Quote
Old 12-07-2016, 11:51 AM   #11
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Buy a 4th brake light, plug in the reverse light harness, don't do any of the other wiring. Boom, plug and play.
Basically, the only "complicated" wiring you need to do with the aftermarket 4th brake lights is the wiring for the brake and running lights. Since you don't want ANY light, you can skip all of that. But if you haven't understood by now, the reverse lights are in the 4th brake light, and that is a simple "plug and play" harness.
You can also install Diode Dynamic's "Tail as Turn +Backup" module and remove the 4th brake light completely. http://www.diodedynamics.com/store/c.../category/622/
PandaSPUR is offline   Reply With Quote
FR-S Headlight Reflector Blackout DarrenDriven DIY (Do-It-Yourself) Guides 476 09-26-2020 03:39 PM
Best bulb for reflector headlight? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 2 02-08-2014 10:33 AM
BRZ Premium Reflector Replacment Jimmylightning Cosmetic Modification (Interior/Exterior/Lighting) 1 11-21-2013 12:35 AM
Red Nightshades on the reflector triangle tbwoodlee Cosmetic Modification (Interior/Exterior/Lighting) 0 01-09-2013 11:10 AM
Rear fog light/ reflector bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 3 12-16-2012 01:37 PM
