Old 12-06-2016, 02:26 PM   #1
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Interior rearview mirror rattling/moving with subwoofer
Hello all,
Not a recall or TSB, but certainly annoying.
I just installed a 10" subwoofer and amp combo in my car last week, as I felt the OEM system was missing that low-end punch, and I'm a bass guy through and through, so I wanted to remedy that. First time I've had an aftermarket sub in one of my cars since '09, so I was really looking forward to it.
However, something annoying has popped up.
When the bass hits at a certain frequency, it rattles the FUCK out of the interior rearview mirror, to the point where the mirror moves out of position. To the point where I'll look at the mirror and realize I'm looking at the ceiling of my car. It makes a loud "buzzing" sound when it moves, as if it's loose on the "rod" that holds it to the windshield or something.
This means I either A) have to keep the bass levels lower than I want to, therefore not getting the punch I desire, or B) have to keep adjusting the mirror every 30 seconds to put it back to where it was so I can actually see behind me.
Now keep in mind I don't have the bass turned up to ridiculous, EXTREME levels, at least not in my opinion (this is subjective of course). But it's really annoying me; the moving AND the rattling/buzzing sound it makes when doing so.
Is there a way I can secure it better or do something to stop it from moving?
Anyone on here with aftermarket audio have the same problem? If so, have you developed a jimmy-rig or some kind of solution to stop this from happening? It's driving me nuts.
Thanks!
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 12-06-2016, 07:18 PM   #2
humfrz
You might try tightening up the mirror ......
Maybe use a little Loctite ..??
When your car's lug nuts start to unscrew ...... that's waaaaay too much base .....
humfrz
Old 12-06-2016, 07:37 PM   #3
SLVRSRFR
humfrz
I was trying to think of a way to tighten it and I'm not even sure how I would go about that.
I could take the mirror off the glass, but I don't know if the mirror itself easily comes off of the stick it's mounted to.
And if I put Loctite on there, wouldn't it be pretty much locked in place for good?
I'm usually a pretty creative guy that can figure out stuff like this myself, but this one has me stumped.
@bpennerz
Old 12-06-2016, 07:40 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
there are different colors of loctite with different strengths.... Uh, there it is..
Removable & serviceable in every color
High Strength Permanent Red LOCTITE® Threadlockers..
Medium Strength Removable Blue LOCTITE® Threadlockers. ...
Low Strength (small thread) Purple LOCTITE® Threadlockers. ...
Old 12-06-2016, 09:43 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
Reinforce the glass.
Gunman is offline   Reply With Quote
Old 12-06-2016, 10:48 PM   #6
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Packofcrows is offline   Reply With Quote
Old 12-07-2016, 09:34 AM   #7
stevesnj
stevesnj's Avatar
Just replace the mirror. It has too much movement.
My 2016 Build thread
Old 12-07-2016, 02:07 PM   #8
SLVRSRFR
Originally Posted by Packofcrows View Post
Funny you say that, as I had a wide-angle mirror clipped on to my OEM mirror. Had to take it off once I got the sub in, because the extra weight on the mirror would cause it to move down immediately after every bass hit. Then it simply fell off because of the vibrations.
Now with that mirror removed, the OEM mirror moves UP when it vibrates (so that I'm looking at the ceiling).
@bpennerz
Old 12-07-2016, 02:12 PM   #9
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
My BRZ rearview has had a stripped screw since I bought it.
Tried locktite, didnt hold.
Used JB weld and it DID work until I had to have the windshield replaced and the tech removed the screw that had been glued in.
Now it wobbles again and I havent gotten around to using the JB weld again.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 12-07-2016, 08:51 PM   #10
Packofcrows
haha bolt in on in mid and two sides. Maybe then it wont move? haha
Old 12-07-2016, 11:03 PM   #11
humfrz
YIKES! to you LOUD music lovers....... just think what's happening to your brain ......let alone your ears .......
At age 73, I have an excuse for not being able to hear worth a damn ...... what's gonna be yours ...... ??
humfrz
Old 12-08-2016, 03:03 AM   #12
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
I have a 10" sub in my trunk as well. I see vibrations in my OEM mirror but it NEVER physically adjusts itself or falls, no matter how loud I have Drake turned up
It sounds like your mirror screw is loose (or if tightening doesn't solve the problem... stripped). I suggest buying a new aftermarket borderless mirror with homelink controls online - there's a few on different sites that I have my eye on.
On another note I'm sure you hear all the other ridiculous rattles this car makes with a sub too - mine makes this awful noise somewhere in the backseat, I think it's the 3rd brake light against the window. The door mirror controls in either door also rattle at the right frequencies.
treminaor is offline   Reply With Quote
Old 12-08-2016, 01:34 PM   #13
SLVRSRFR
Yeah the rear tray where the 3rd brake light is rattles like a bitch too, but that's more of a minor annoyance compared to the mirror.
@bpennerz
Old 12-08-2016, 01:38 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The weaker versions of thread lock become "rubbery" compared to the stronger versions. You will be able to adjust your mirror, it will just be stiffer.
Start with one or two drops around the ball joint. It won't become brittle like superglue.
I wrapped mine to fix the rattle...
DIY: Disable Compass Rearview Mirror (Auto-dimming Mirror) CIAGDDS DIY (Do-It-Yourself) Guides 17 05-15-2020 12:50 PM
Black interior pieces and Rimless Rearview Mirror pooch Interior Parts (Incl. Lighting) 1 09-16-2016 07:15 PM
Rearview Mirror O.Z. BRZ Issues | Warranty | Recalls / TSB 2 10-12-2012 08:43 AM
New Rearview Mirror tonystewart Cosmetic Modification (Interior/Exterior/Lighting) 23 06-10-2012 02:52 PM
