Old 04-17-2015, 08:47 PM   #1
teamturbo
teamturbo's Avatar
Bad suspension squeak
Okay, I had this develop after a rainy day about 5-6 days ago...how the hell do I go about fixing this? It sounds like someone is having sex in my car everywhere I go. Quite embarrassing and annoying the hell out of me.
[ame="https://www.youtube.com/watch?v=c-8r3JJfB8M"]VID 20150417 165627 - YouTube[/ame]
teamturbo is offline   Reply With Quote
Old 04-17-2015, 10:46 PM   #2
wparsons
wparsons's Avatar
That is exactly why you have a warranty, just take it to the dealer.
Without looking closer it'll be hard to figure out what part is making the noise, there's a few places that could be making it.
flickr
Old 04-17-2015, 11:09 PM   #3
teamturbo
teamturbo's Avatar
Problem...I'm running the Eibach Pro Drop on it for 1.5 years and I tossed the stock springs into the garbage.
Old 04-18-2015, 12:43 AM   #4
8R6
8R6's Avatar
Drives: FRS
Hahhahahhahah it does sound like a squeaky bed during sex rofl! Sorry but that shit is spot on for the sound LOL
As for the problem, damn your car bounces way too easily. Maybe your strut is blown. It shouldn't be that easy to move the car that much that frequent just by hand.
8R6 is offline   Reply With Quote
Old 04-18-2015, 01:17 AM   #5
teamturbo
teamturbo's Avatar
The trunk is open and I'm using my entire body to press down on the suspension. I don't think the strut is blown. The car is only lowered 1 inch. Come to think of it, it's been lowered 12 months and about 6-7K miles on the lowering.
Old 04-18-2015, 01:25 AM   #6
8R6
8R6's Avatar
Drives: FRS
Oh ok them probably not the struts. But that still sounds a romp on a bed lol
Old 04-18-2015, 01:32 AM   #7
teamturbo
teamturbo's Avatar
Lift it and blast WD-40 on every piece of metal?
Old 04-19-2015, 12:46 AM   #8
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
this is the right direction.
There are a couple rubber bushings on the control arms and such and without a stethoscope you can just spray a bushing and test and try another one to find the one thats squeaking. It sounds kinda like a rubber squeak.
DieselDog is offline   Reply With Quote
Old 04-19-2015, 10:39 AM   #9
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
That sounds more like metal on metal than a squeak...
Old 04-19-2015, 10:41 AM   #10
wparsons
wparsons's Avatar
^^ Agreed on that.
flickr
Old 04-19-2015, 11:18 AM   #11
teamturbo
teamturbo's Avatar
It might be the exhaust. I back into my parking spot and made contact with an exhaust pipe by the differential a week or two ago against the parking block. I hope it loosened a bracket that holds it in place. Need to take it in for a lift.
Old 04-19-2015, 01:01 PM   #12
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I agree with the WD40. If you lift it, and reproduce the squeak youll be able to see much more clearly...now the rain is gone
Old 04-19-2015, 01:51 PM   #13
ls1ac
ls1ac's Avatar
If you spray one point at a time you can find the offending point. if you spray all over it will go away for a while but you will get to start all over when the squeak starts again. Once found you can clean the rest off end use grease or silicone (metal or rubber) as needed in the one place. General spraying will collect dirt.
Front suspension squeak going over bumps Gords_zenith Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-19-2017 09:57 AM
steering wheel squeak?? frsqc Issues | Warranty | Recalls / TSB 10 02-26-2015 01:50 PM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
Rear squeak norcal_brz Issues | Warranty | Recalls / TSB 0 08-12-2014 07:29 PM
Belt squeak after washing car? VesperLynn BRZ First-Gen (2012+) — General Topics 2 12-16-2013 09:46 PM
