Old 11-30-2016, 04:31 PM   #1
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Moving up from 225's to 245's
[IMG]http://img.photobucket.com/albums/v163/sacairsoftsnoopy/BRZ/***939E2-A4D6-4448-ABE3-6CDAC1B1E440_zpsf5wzvuqf.jpg[/IMG]
Currently running 225/45 Michelin Pilot Super Sports on a 17x8.25 wheel.
Car currently has -1.5 degree camber up front. I have SPC camber bolts down low and
I'm thinking about switching to 245/40 of the same tire. Looking at the photos, do you guys think I'll have enough clearance for the said set of tires?
I don't have any set measurements but from the photos, it looks like the clearance is about the same thickness as a coil of the spring...maybe .45 to .5 inch.
Wheel offset is +35. Lowered on RCE yellows.
Thoughts?
Thanks!
SHWNBRZ is offline   Reply With Quote
Old 11-30-2016, 04:42 PM   #2
Amputechture
Drives: 2014 BRZ
Can't view your photos (at work). What is your wheel offset? That will play a big part in determining clearance. For reference, I am on 17x9 35 offset----245/40 tires lowered roughly 1.25 inches on stock struts with -2.1 camber up front and I have no clearance issues whatsoever. Unless you have a really high offset I would say you'll be okay.
Amputechture is offline   Reply With Quote
Old 11-30-2016, 04:51 PM   #3
SHWNBRZ
I am on stock struts.
Old 11-30-2016, 09:21 PM   #4
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
It will be close. I have seen some that are fine, and some that are not. It kind of depends on the tire. I am looking at facing the same issue when my stockers need replacing.
Vampyre is offline   Reply With Quote
The Following User Says Thank You to Vampyre For This Useful Post:
SHWNBRZ (12-01-2016)
Old 12-01-2016, 03:06 AM   #5
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I wouldn't think you'd have any issues. I have 245/40 PSS on 17x9 wheel with +35 offset. Lowered with the springs (although that doesn't matter here) and am also using camber bolts (lower) for -1.x degrees (not quite -1.5, but i forget). But, realistically, you can assume the tire to be about 1cm wider on each side. That's like 1/3 of an inch, so still within your estimated gap, but maybe close.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Old 12-01-2016, 02:06 PM   #6
SHWNBRZ
Thanks for the input.
If anything, I suppose I can put a 3mm spacer on, then roll out to dial down the camber if I need more clearance.
Old 12-11-2016, 02:16 PM   #7
FRSKEV
Drives: FRS
You'll have no problem fitting them, I had RCE springs with 17x8 35offset wheels and 245/40/17 Dunlop ZIIs running -1.5 camber up front. No issues at autox or track.
2013 Scion FR-S
Autox - Track
Paint Protection Film Pro
FRSKEV is offline   Reply With Quote
Old 12-11-2016, 02:25 PM   #8
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
The MPSS in 245/40R17 runs narrow. While this may allow for more clearance, its only .3" wider than the 225/45R17. Fitment shouldnt be an issue but is the cost increase really worth the minimal size increase
Jrdad is offline   Reply With Quote
Old 12-15-2016, 01:59 AM   #9
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
youre only going to have a few mm clearance but you will be ok, full lock and everything. i ran that same setup with no issues.
Legionsk88 is offline   Reply With Quote
Old 12-28-2016, 10:37 PM   #10
v1beeee
Drives: 14 FRS Whiteout
Do you have any photos of your 245/40/17 on 17x8 wheels?I have the same spec wheels and I'm thinking of moving from a 245/40/17 from a 225/45/17 and I'm just curious as to how much different it feels and how it looks.I'm also debating RCE springs so any help would be great!
v1beeee is offline   Reply With Quote
Old 01-03-2017, 05:46 PM   #11
FRSKEV
Drives: FRS
Yes I have some pics in a thread I have a while ago, check my threads. Its a nice flush look with meaty tires. When it comes to difference in feel, it's not much different from stock just has more grip all around ( currently have a wider set up 255/40/17 on 17x9 wheels and love it ). Personally I don't understand why people are scared of bigger tires, it doesn't change the nice nimble feeling the car has stock. @v1beeee
2013 Scion FR-S
Autox - Track
Old 01-03-2017, 06:17 PM   #12
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Running 245/40/17 Michelin Pilot Super Sports on 17x9 +35-- camber set to -1.9 up front using camber bolts.
  • Previously used TRD springs with no clearance issues
  • Currently using Bilstein B14 with height lower, no clearance issues
Also previously had 225/45/17 on both stock wheels and on the same 17x9s
asdf is offline   Reply With Quote
Old 01-08-2017, 10:03 PM   #13
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
I'm running 245/40 on 17x9+35 RPF1s
30mm drop, -2.5 camber
No rubbing
blue cat is offline   Reply With Quote
Old 01-09-2017, 02:53 PM   #14
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Meh, don't do it. stay skinny.
Moving to Oahu RedLeader Hawaii 54 12-06-2015 09:26 PM
Moving Up Into the Bay! Bonburner Northern California 14 07-30-2015 05:54 PM
Moving to Borden KonTheory CANADA 21 09-24-2014 02:08 PM
Moving to Landstuhl Danielft86 EUROPE 1 11-16-2013 11:18 PM
Moving to Tx brz007 Southwest 3 08-26-2013 09:47 PM
