Old 11-23-2016, 07:47 PM   #1
Songha
Songha's Avatar
Drives: 2013 Scion FRS
Got rear ended, car won't start?
The light turned red and I stopped, after stopping I heard tires screeching and got rear ended HARD. Back, shoulders and neck feels like crap. Long story short, I turned the car back on, back it into an empty lot and exchanged information. He knew he was and not fault, it all went well until we were about to be on our way. My FRS would start. Won't crank or turn over. No idea why given I was and not let to park the car in the lot after getting hit.
It doesn't look like much but the trunk doesn't close, the crash bar/bumper or whatever caused the frame for the trunk to cave in, upwards from what I can see from under the car.
From the looks of it, I'd need a new bumper, bumper cover, trunk and the frame of the trunk fixed. Aside from that, I was wondering if maybe some anti theft crap engage or there's a cutoff switch for the for fuel or something causing it to not start. I'm at a loss.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
Songha is offline   Reply With Quote
Old 11-23-2016, 07:51 PM   #2
gramicci101
Off Topic
Do the interior lights and radio work? If not, check the battery connections. The impact may have knocked them loose.
Old 11-23-2016, 07:56 PM   #3
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
My bet is on neutral safety switch...
Is it an Auto? If auto, try starting in neutral and moving the selector linkage...
If it is a manual, make sure clutch is all the way depressed and floor mat is not blocking it
nextcar is offline   Reply With Quote
Old 11-23-2016, 08:11 PM   #4
Zhangy
Drives: 2015 FRS
get it to the dealer, they do a scan and will probably know whats wrong
Zhangy is offline   Reply With Quote
Old 11-23-2016, 09:47 PM   #5
Songha
Songha's Avatar
Interior lights work, radio stopped working. Connections to the battery posts are good.
Clutch was fully pressed when trying. It started right up immediately after it was hit. Didn't start after I turned it off the second time when I parked it in a lot.
Plugged up my OBDII reader and my OFT and neither showed anything out of the ordinary.
Old 11-23-2016, 10:06 PM   #6
jg7
Drives: 2016 Scion FR-S
Maybe a pinched fuel line?? Ran until ran out of gas....???
jg7 is offline   Reply With Quote
The Following 2 Users Say Thank You to jg7 For This Useful Post:
lantsalot (11-29-2016), Ultramaroon (11-23-2016)
Old 11-23-2016, 10:23 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Ooooo! Hmmm...
Old 11-23-2016, 10:27 PM   #8
Ultramaroon
not playing cards
Can you hear the fuel pump run for a few seconds when you turn on the ignition? It should pump up pressure on the rail.
Leonardo (11-23-2016)
Old 11-23-2016, 10:29 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Check the 7.5 amp "stop" fuse. It incapacitates the car. It's an additional safety feature.
Old 11-24-2016, 05:29 AM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
To those who are suggesting fuel pump- no crank at all.
We know it's not the fuel pump or battery or battery connection. He has power and the engine won't crank at all. When you turn the key, do you here a click from the engine area? Listen at the fuse box while someone turns the key, you're looking for the sound of a relay clicking. Listen near the starter for a much louder single click from the starter. Get back to us
Also- it's a standard right? Did you try to push start it?
Old 11-24-2016, 09:49 AM   #11
Songha
Songha's Avatar
That was a typo. It won't start after I was able to move it from the street. No noise at all.
Old 11-24-2016, 12:20 PM   #12
gravitylover
It's this. Most cars for the last ten years or so have a cutoff that disables the car when it's been hit. I was involved in a chain reaction a few years ago and the Audi behind me showed no damage at all but wouldn't start and couldn't even be put in neutral to roll it out of the way. Really pissed the cops off too because it had the ramp onto the interstate completely blocked so about 15 of us lifted it out of the way to get the road open again.
The Following User Says Thank You to gravitylover For This Useful Post:
Leonardo (11-24-2016)
Old 11-24-2016, 12:43 PM   #13
Songha
Songha's Avatar
I hope this is it. Im sure the damage is already well over 4 5k. Covered obviously but I won't be able to drive it while it's being repaired. I will be heading out to check on it soon. Will update.
The Following 4 Users Say Thank You to Songha For This Useful Post:
gravitylover (11-24-2016), Leonardo (11-24-2016), Tcoat (11-24-2016), Ultramaroon (11-24-2016)
Old 11-24-2016, 02:33 PM   #14
Ultramaroon
not playing cards
Whoops. I missed this.
Rear ended S84kam Scion FR-S / Toyota 86 GT86 General Forum 58 09-13-2015 02:27 AM
rear-ended jarviz Scion FR-S / Toyota 86 GT86 General Forum 22 11-12-2013 04:38 PM
GOT REAR ENDED!! Howardwei Cosmetic Modification (Interior/Exterior/Lighting) 4 09-18-2013 01:20 PM
brz rear ended bjun BRZ First-Gen (2012+) — General Topics 100 05-09-2013 02:53 AM
Rear Ended travace Scion FR-S / Toyota 86 GT86 General Forum 10 01-12-2013 12:15 PM
