Old 11-22-2016, 01:52 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
2mm spacer options
Having trouble finding 2mm (alternatively considering 3mm) spacer options. Anybody?
Old 11-22-2016, 02:02 PM   #2
gramicci101
Off Topic
Here's 3mm. I'm still looking for 2mm.
https://www.amazon.com/5x112-5x100-H...100+3mm+spacer
EDIT: If you would rather buy from a forum vendor, @Mach V Dan makes 3mm spacers as well. They're a little more money, but they seem nicer. He might be able to make 2mm spacers for you.
http://www.fastwrx.com/collections/w...-wheel-spacers
The Following User Says Thank You to gramicci101 For This Useful Post:
switchlanez (11-23-2016)
Old 11-22-2016, 02:08 PM   #3
2mm is .07 of an inch. Doubt they bother to make anything that small. What would be the point?
geezerbrzeezer (11-22-2016), go_a_way1 (11-22-2016), mrg666 (11-22-2016)
Old 11-22-2016, 02:10 PM   #4
gramicci101
Off Topic
To clear components without switching out the lugs. 2/3mm is about all you can do and still have enough threads to engage the lugnuts.
Tcoat (11-22-2016)
Old 11-22-2016, 02:12 PM   #5
Well that is calling things pretty close then!
Old 11-22-2016, 02:16 PM   #6
gramicci101
Off Topic
I agree, but he's also going to run into fender clearance if he goes out too far. He just posted a thread about inner fender/frame clearance issues and camber, and I think he's running 18x9.5+43 wheels. He doesn't have a lot of room to play with.
@switchlanez, you may want to look into restricting the steering angle. Velox makes shims for steering racks that they include with their brake cooling kits in order to keep the wheels from turning enough to hit the ducts. They might sell you some shims directly.
Tcoat (11-22-2016)
Old 11-22-2016, 02:28 PM   #7
switchlanez
Thanks. Yes also considering those steering stops. Here's my BBK clearance issue on TWS T66-F 18x8.5 +42. Looks like a fraction of a mil. Good thing Discount Tire wrote me a check covering full cost of wheels and caliper touch up for not checking clearance before returning my car.
Sent from my Pixel using Tapatalk
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
RuyGuy2 (04-23-2020), Tcoat (11-22-2016)
Old 11-22-2016, 02:39 PM   #8
gramicci101
Off Topic
Ouch. Those aren't cheap wheels, either.
If you don't mind new studs on the front, you could fit 5mm spacers with no problem, and 15mm on the rear. You can get bolt-on 15mm spacers, so you wouldn't need new studs on the rear.
Old 11-22-2016, 06:41 PM   #9
empower-auto
Kouki-Monster
empower-auto's Avatar
Absolutely false, unless your wheels are hilariously poor in design.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-22-2016, 06:55 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What is absolutely false? gramicci101 is correct. Adding a spacer that is wider than 3mm is not recommended without replacing the stock studs with longer aftermarket studs.
Some guys are running a 5mm slip, but the amount of threads that engage on your lug nut is questionable.
Judging from your post. "unless your wheels are hilariously poor in design" you did not read that the OP has TWS T66-F. Which are one of the best, lightest, forged, wheels available for our cars.
DAEMANO (11-22-2016)
Old 11-22-2016, 07:17 PM   #11
mrg666
pessimistic skeptic
mrg666's Avatar
I would return/sell those wheels instead of trying to make them fit with spacers. Those wheels need to be 18x8 +38.
Old 11-22-2016, 07:38 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x8.5 +42 has 2+mm more clearance than a 18x8 +38 for OPs BBK.
18x8 +38 has 4mm different offset than +42, but 18x8.5 adds 12.7mm or 6.35mm on each side of the wheel. Math.
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
DAEMANO (11-22-2016), RuyGuy2 (04-23-2020)
Old 11-22-2016, 08:34 PM   #13
mrg666
pessimistic skeptic
mrg666's Avatar
38 mm offset moves the wheel 4mm out compared to 42 mm to avoid rubbing inside wheel. Since the wheel itself is 6.25 narrower on each side, it doesn't poke out as well. What was your math grade?
Old 11-22-2016, 08:55 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Offset is measured from the center of the wheel.
Rodn333y (11-23-2016), RuyGuy2 (04-23-2020)
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
