Old 11-21-2016, 10:34 AM   #1
AnthonyArcaro
AnthonyArcaro's Avatar
Drives: 2014 White Subaru BRZ Limited
Someone who is good with wheel figment please tell me if this would fit?
Currently running eibach springs on stock struts (drops about an inch).
Was wondering if I got 18x9.5 +35 offset with some 235 on the front and 245 rears would fit without rubbing issues?
Can someone recommend me a good setup since I am kind of stuck with the 18x9.5 +35 wheels since I already bought them. Maybe I need coils?
Thank you,
Anthony
Daily 2014 Satin White Pearl BRZ Limited
Instagram: @subyota
AnthonyArcaro is offline   Reply With Quote
Old 11-21-2016, 10:50 AM   #2
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I can't help you with whether or not they will fit correctly but If you are going to run 4 18x9.5 wheels why not just run all 245s or all 235s? It would make tire rotations a lot easier and the car was designed with a square setup from the factory. 245/35/18 is very close to the overall diameter of the stock 215/45/17 so you won't have a significant difference on your speedometer vs actual speed.
Also check out the wheels/tires sub section. People on there will be much more knowledgeable and there should also be a "will it fit" calculator
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 11-21-2016, 11:02 AM   #3
Surge
I'd go down to a 225. Thats what I'm using on 9.5 +30 and at -1 deg rear camber I'm damn close to rubbing.
Surge is offline   Reply With Quote
Old 11-21-2016, 11:05 AM   #4
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
Thank you,
Anthony
I can't say for sure, but I've got about 2-3mm of clearance running 17x9 +38 wearing 245/40/17 on TRD springs (roughly 1 inch drop). Even with the additional space your offset provides versus mine, I think the additional diameter may rub. It's going to be pretty close I think.
I used to have a staggered setup with the front running 18x8.5 +33 wearing 235/40/18 and I didn't rub. You've got an extra inch of wheel that'll pull the tire closer to the strut and a less aggressive offset.
My recommendation for you would be to bite the bullet and get some good coilovers. Then run 245 or 255 width tires in a square setup on those wheels and enjoy.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 11-22-2016, 04:36 PM   #5
adjusts
adjusts's Avatar
Drives: 86
You would fit nicely with a 235 in the rear.
adjusts is offline   Reply With Quote
Old 11-22-2016, 06:28 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Read page one.
http://www.ft86club.com/forums/showthread.php?t=41083
Most members that run 9.5 wide wheels have coilovers to fit properly in the front. The thread explains things better. I would rate it top ten on the forum.
Old 11-23-2016, 03:41 AM   #7
tyler_win_photo
tyler_win_photo's Avatar
Will probably need coils. I would also suggest at least 245s, as 235s are quite stretched on 9.5s - unless that's what you were going for.
tyler_win_photo is offline   Reply With Quote
Old 11-23-2016, 03:48 AM   #8
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
You're going to need coils, the wheel won't clear the stock strut. Besides that I would go with a 235, should get a nice stretch and will still look and perform well.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
fitment, wheels
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 10:50 AM
Anyone know a good wheel powdercoater around LA/SFV? hakkoo Southern California 3 07-06-2014 09:02 PM
Bad figment on Borla exhaust diffuser? sittinSideways Engine, Exhaust, Transmission 12 05-30-2013 06:25 PM
Perrin drop in figment issue Tiremonkey0824 Engine, Exhaust, Transmission 23 01-11-2013 10:01 PM
What looks good to you in a wheel? madfast Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 01-10-2012 10:32 PM
