Northwest AK, ID, OR, WA
Old 11-19-2016, 03:04 AM   #1
IgamaS
Drives: 2015 Whiteout FRS
Exhaust installation help
I bought an exhaust finally, and now I attempted to install the exhaust but can't get the bolts off of the old exhaust. So with that I was wondering if anyone can recommend any shops that can do the job for a good price. Or if anyone is willing to help if possible, it would be greatly appreciated.
IgamaS is offline   Reply With Quote
Old 11-19-2016, 12:40 PM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
PB Blaster works wonders if you didn't try that yet. Spray it all around the bolt and threads and wait 5 minutes, spray again then try. Also get a breaker bar from Harbor Freight. Put all 4 corners up on jack stands so the car is high enough to get some leverage. Make sure you put a couple spare tires under the jack points so if an earthquake occurs and the car falls off the jack stands that it won't end you.
I'm not sure where Shoreline is but if you'd like to come to Beaverton I can help you. I'm sure there are a lot of other people on here that would help but they probably aren't reading this so perhaps be patient?
stockysnail is offline   Reply With Quote
Old 11-19-2016, 12:53 PM   #3
Brayden_23
Drives: Asphalt 2015 FRS
Some generous application of WD40 should do the trick just fine. If you try that and it still fails, I could probably swing by to help. Just PM me.
Brayden_23 is offline   Reply With Quote
Old 11-19-2016, 01:01 PM   #4
stockysnail
Just the tip
PB Blaster works better than WD40 in my experience.
Old 11-19-2016, 01:14 PM   #5
Brayden_23
Hey now, it's not a competition. Was just throwing out WD40 since it has a higher chance of laying around somewhere in OP's garage. Not saying it works better or worse, but either way it will get the job done.
Old 11-19-2016, 01:15 PM   #6
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Simple diesel oil is pretty good too. Wire brush any opposed threads and brush on. Reapply a couple of times and leave overnight. Use a six sided socket with a breaker bar or impact tool.
Scrappydoo is offline   Reply With Quote
Old 11-19-2016, 03:24 PM   #7
stockysnail
Just the tip
I wasn't trying to make it a competition. Just telling him from experience if he sees both that he should get PB Blaster instead of WD40. No need to take it personal as I didn't mean anything by it.
Old 11-19-2016, 03:59 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Best stuff for stuck bolts, is 50% auto trans fluid 50% acetone mix. Works far better than anything else listed in this thread.
Decay107 is offline   Reply With Quote
Old 11-19-2016, 10:33 PM   #9
Brayden_23
I agree, if OP goes to pick up something to help remove bolts, PB blaster is better than WD40. Just throwing out that WD40 would probably do the trick since the car is still relatively new. Guess things are just getting misconveyed. Hope OP figured it out!
NYC Exhaust Installation dad&sonFRS NY / NJ / CT / PA 11 03-29-2014 05:00 AM
Exhaust Installation Drive Northern California 20 03-21-2014 01:04 PM
Exhaust Installation congee CANADA 6 03-12-2014 01:00 PM
Nameless Exhaust Installation Mach5 Mid-Atlantic 10 06-18-2013 09:40 PM
Exhaust Installation in Adelaide yomchi1989 AUSTRALIA 2 12-06-2012 02:38 AM
