Old 11-14-2016, 01:07 PM   #1
BXRCHTR
Cool Help! I want a turbo kit for my BRZ
So I have a decent fund going on for this car now. My goal for this car was for 500 whp (maybe I can get that now but that can always wait) I have a 2013 Subaru BRZ limited AT and I would like to turbo it for around 5k (I can do more if I really have to) What's my best option and what is everything I need?
BXRCHTR is offline   Reply With Quote
Old 11-14-2016, 01:18 PM   #2
http://www.ft86club.com/forums/showthread.php?t=81428
Cole (11-14-2016)
Old 11-14-2016, 01:24 PM   #3
gramicci101
Off Topic
If your goal is 500 whp it'll be easier and maybe cheaper to buy a Mustang or Camaro and mod that instead. $5K is only the entry fee for that rabbit hole.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
SleepingPanda (11-14-2016), Tcoat (11-14-2016)
Old 11-14-2016, 02:39 PM   #4
SleepingPanda
Drives: 2016 BRZ Hyper.Blue
^ what he said. honestly at 5k. your only option is the SBD turbo kit. and with an E85 kit an injectors and tune. youd be closer to 6000. and only at around 400whp. plus at 500whp with a stock block. you're a ticking time bomb. So when the motor blows. expect to spend another 8000-10000 for a built motor. Plus you'd need a bigger turbo than a 20g that the SBD kit uses. So you'd be better off with a kit that uses a GTX3076r. with a built motor and lots of boost and e85. you should see 500whp. now can the rest of the car handle it?
I think you're looking at just north of 20,000 for 500whp.
SleepingPanda is offline   Reply With Quote
Old 11-14-2016, 02:44 PM   #5
chaoscentral
Drives: 2013 Scion FR-S Series 10
They actually came out with a bigger turbo kit that utilizes a GTX3076r size/style turbine. its an extra $500 or so. Can get everything all in minus the stuff for E85, but includes literally everything else including tune for $4200(provided you already have an Ecutek or OFT)
But to the OP, as others have said 500rwhp on a stock motor is just a time bomb waiting to go. Would need way more on top of just a turbo kit to be at that figure reliably, and also requires access to E85.
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 11-14-2016, 03:30 PM   #6
Tedderple
Drives: 2015 FRS Halo (White)
The biggest problem here is that over 210-250ft/lb of torque, the automatic transmission will start slipping.
AVO Turbo with FlexFuel| Perrin 2.75" CAI(gone) | Now: Perrin 3" Catback | MXP Comp RS Catback(gone) | Magnaflow Catback(gone) | Gruppe-S UEL Headers (gone) | 18x7.5 TE37 on Firehawk Indy500 225/40/18 | Valenti Tail Lights | Drift-Office Tuned 220whp-350whp
Tedderple is offline   Reply With Quote
The Following User Says Thank You to Tedderple For This Useful Post:
go_a_way1 (11-14-2016)
Old 11-14-2016, 03:33 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah I need to put mine on a dyno before I see about increasing the boost for this exact reason. So far no slippage for me
Old 11-14-2016, 03:41 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
500 whp for 5k is not realistic. You will turn your car into a contraption and hate it in the end if you try that. Either raise your budget to 12k or reduce your target to 250 whp. Actually, I would recommend reading and researching a little more.
Old 11-14-2016, 03:44 PM   #9
Tedderple
I'd be interested to know current and increased boost PSI, WHP, and torque increase if and when you get to it.
Not sure of the exact torque range, just threw out what I could remember.
Old 11-14-2016, 04:03 PM   #10
johl
johl's Avatar
Drives: toyota 86
I also agree with all that has been said. However if you manage to get a turbo kit with a garret gtx3076r and only run it on low boost (8 psi) you should be fine to not build the motor or transmission yet. Yes it will suffer a little bit of turbo lag but if you manage to get a twin scroll manifold this will be reduced by a few hundred rpm.
At a later date when you are used to the 300hp you will get on low boost you can save for a motor build so you can finally get the most out of your turbo
johl is offline   Reply With Quote
Old 11-14-2016, 04:15 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Right now I am at 10psi and estimating 280whp range based on my buddies SC FRS. It wont be till spring when I get it on a dyno though :/
Tedderple (11-15-2016)
Old 11-14-2016, 06:17 PM   #12
SleepingPanda
I've seen the new turbo kit. And size/style isn't the same. It's not a gtx3076r and never will be. Don't get me wrong. It's a fantastic kit for the money. But don't be fooled by 'includes a tune'. You should always always always get a custom tune for your car especially with f/I
Old 11-14-2016, 06:32 PM   #13
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
That auto trans...
The auto trans on the twins is supposed to be good for quite a bit more than 250 lb ft with a good trans cooler.
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
Old 11-14-2016, 06:40 PM   #14
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Jaden
I am gonna find out soon enough lol
Jaden (11-14-2016)
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 10:56 PM
Toyota Trademarks: D4-S Turbo, More turbo, 9 Scion Names Veloist Off-Topic Lounge [WARNING: NO POLITICS] 9 08-27-2014 11:29 PM
