Old 11-13-2016, 01:53 AM   #1
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Antifreeze QD mix?
I would like to have some QD mix in my car over the winter so I was looking for some advice on how to mix up a batch. For example do you think mixing some up with windshield antifreeze would be a good or bad idea or could I just add alcohol to a bottle of some already mixed QD?
Thanks for any thoughts
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 11-13-2016, 12:04 PM   #2
What is a QD mix?
Old 11-13-2016, 12:32 PM   #3
FLYFISHR
FLYFISHR's Avatar
quick detailer
Old 11-13-2016, 12:40 PM   #4
gramicci101
Off Topic
I'm not sure I understand. You want to add antifreeze to your quick detailer and then spray it on the paint?
Old 11-13-2016, 02:16 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Try putting your QD in the freezer to see if it really does.
The additives already there may significantly reduce the freezing point.
Old 11-13-2016, 05:29 PM   #6
humfrz
From the pictures that @Tcoat has posted showing Canadian roads in the winter ....... you might as well add salt to your QD mixture to reduce the freezing point ......
humfrz
Old 11-14-2016, 01:04 AM   #7
FLYFISHR
FLYFISHR's Avatar
Thanks for the idea. I was thinking of using the windshield fluid that's good down to -40 to make the quick detailer mix, that way I can leave a spray bottle in the trunk without worrying that it would freeze, split the container at leak all over when it thaws. I'm hoping (trusting) that the windshield fluid should be safe to use on the paint finish if I had to remove bird crap or stuff like that.
Old 11-14-2016, 01:07 AM   #8
FLYFISHR
FLYFISHR's Avatar
Not the antifreeze that you use in the engine cooling system, but the kind you use with your windshield washer.
Old 11-14-2016, 02:32 AM   #9
humfrz
[ame="https://www.youtube.com/watch?v=pavmxMM2KlA"]Detailing Spray Freeze Test - 25ΒΊ - Will it FREEZE? - YouTube[/ame]
Good information ..... if you can stand the music.....
humfrz
HELP!!! I SMELL ANTIFREEZE ravenblackfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 04-30-2016 09:36 PM
Antifreeze /coolant... cooldandani Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 12-15-2013 12:23 AM
