Old 11-07-2016, 07:59 PM   #1
Norinradd
Drives: 2013 frs
Whiteline KCA416 ?? 16 or 14mm
I thought we needed 14mm for thw whiteline camber bolts. Frmotorsports.com part number is for 16mm
Which is it we need!?
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-07-2016, 08:06 PM   #2
wparsons
wparsons's Avatar
30 seconds on the whiteline site found your answer:
http://www.whiteline.com.au/product_...CA416&sq=22291
Look at the section for applicable vehicles.
flickr
Old 11-07-2016, 10:40 PM   #3
strat61caster
strat61caster's Avatar
There's a couple very informative threads out there about the details.
http://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
wparsons (11-08-2016)
Old 11-07-2016, 10:47 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
...dude
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
Tcoat (11-08-2016), wparsons (11-08-2016)
Old 11-08-2016, 10:13 AM   #5
Norinradd
Drives: 2013 frs
Originally Posted by Summerwolf View Post
...dude
Well im sorry amazon and a bunch of ppl here say 14mm
Old 11-08-2016, 01:22 PM   #6
wparsons
wparsons's Avatar
Seriously? If you already know the answer then why are you asking a question? If there is a thread with answers, chances are you're going to get the same answers again.
You need to read the context of what you're looking at better. Are the people that are suggesting a 14mm bolt talking about a lobed bolt (like the whiteline), or a solid one (like the factory crash bolts)?
Next time you have a question, re-read the information that's already in front of you. I'd be willing to bet that you already have everything you need to know in front of you, you just need to understand what you're reading.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
D_Thissen (11-09-2016), Summerwolf (11-08-2016), Tcoat (11-08-2016)
Old 11-08-2016, 01:40 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Here is what I would do in your situation.
http://www.ft86speedfactory.com/whit...l#.WCIbwk3rthE
They don't even say a MM size, they're just selling you the right product. No thought needed.
Then again, information being given to you left and right.
Old 11-08-2016, 08:31 PM   #8
Norinradd
Drives: 2013 frs
Why do you need to coach me. What does it matter what type of bolt they were talking about.
You can ramble for 30 sentances but you cant just say "14 or 16"
I read conflicting opinions and part numbers. Just wanted a straight simple answer. Thanks though
Old 11-08-2016, 08:33 PM   #9
Norinradd
Drives: 2013 frs
Yah i boughtem this morning. Just on a couple sites 14mm whitelines. Kca414. Said tey fit on frs. And when i googles 14 or 16mm camber bolt frs. There was a few discusions about it. With people sayine one or the other.
I wanted to order it asap this morning and just needed a straight answer
Old 11-08-2016, 09:32 PM   #10
wparsons
wparsons's Avatar
You're not hearing conflicting opinions, you're hearing different options. There's a subtle, but very important difference.
A 16mm lobed bolt is one option, the other is a 14mm solid bolt. THAT's why what kind of bolt they're talking about matters. Context matters, A LOT.
If you spent half as much time actually reading and comprehending the information already available as you do making a post for every single question you wouldn't need to be asking so many questions (or end up arguing with people trying to help you).
Literally every question you've asked has already been answered on here already, or is information easily available with a quick google search.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 11-08-2016, 10:18 PM   #11
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Actually, although you are correct about the 14mm solid/"crash bolt", I think what is being discussed are the lobed bolts, and whether you need a 14mm or a 16mm lobed bolt.
If you want to adjust camber, the most common way is to use either a 14mm crash bolt in the upper hole or a 16mm lobed bolt in the top hole as you suggest.
It is also possible to use a 14mm lobed bolt in the lower hole and retain the 16mm stock bolt in the upper hole. Unless you have unusual circumstances, you do not want to use the 14mm lobed bolt in the upper hole.
For the maximum adjustment you can use the 14mm lobed bolt in the lower hole and either the 16mm lobed bolt OR the 14mm crash bolt in the upper hole. I do not recommend using the 14mm lobed bolt in the upper hole if you are also using one in the lower hole. The reason being that the 14mm lobed bolt is not as strong/durable as the 14mm solid bolt.
Generally it is not recommended to use both the upper and lower holes for adjusting camber unless it is a track car with regular inspections.
The reason you have conflicting input on 14mm vs 16mm lobed bolts is that some people prefer using the lower hole to adjust camber for technical reasons beyond this discussion. Either hole will work.
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
alphasaur (11-01-2021), Delmar (02-26-2021)
Old 11-08-2016, 10:35 PM   #12
wparsons
wparsons's Avatar
And that's exactly why I asked if the other thread he was talking about was talking about solid or lobed. Without knowing the context you can't get a good answer.
flickr
Conflicting torque spec (83 vs 106 ft-lbs) for Whiteline KCA416 jonnyozero3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-29-2014 12:48 PM
FS: New Whiteline camber bolt KCA416 damaster32 Brakes, Suspension, Chassis 2 03-25-2014 11:55 AM
Whiteline Camber Bolts (KCA416) Steve Canada Classifieds 11 01-07-2014 10:01 PM
