Old 11-05-2016, 03:38 AM   #1
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Looking for Project Kics Experts.
I've finally narrowed down my choice of wheel fasteners: Kics R26. The only caveat is they're open ended, which brings me to my question…
Will R40 Iconix/Revo caps fit on R26 lugs?
I'm on OEM studs and going with an 18Χ8 +45 wheel. Will this leave enough thread on the R26’s to accept the cap?
Thanks in advance!
P.S. Yes I've searched (and searched, and searched some more).
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Old 11-05-2016, 10:33 AM   #2
15limited
15limited's Avatar
I vaguely remembering seeing on a merchants website that the R40 caps will not fit R26 lugs. I'm running r26's tho and there's minimal debris that actually gets stuck in the threads, I wire brush the studs everytime my wheels are off anyways.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
Sosa (11-07-2016)
Old 11-05-2016, 03:27 PM   #3
Apex-Apex
Apex-Apex's Avatar
No, iconix and revo have a lip on the inside of the lug nuts to hold the cap in. It is also why you can't run extended studs with iconix/revo but you can with r26 and r40.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following User Says Thank You to Apex-Apex For This Useful Post:
Sosa (11-07-2016)
Old 11-07-2016, 10:55 AM   #4
Sosa
[||]--(86)--[||]
Sosa's Avatar
This helps a lot. Even as a vague memory it helps that someone out there may have tried. Thank you.
After all I'm sure merchants/manufacturer would advertise the fact if they were compatible.
Iconix caps are threaded & Revo's are clips. So Iconix will accept extended lugs. Still helpful though, thank you.
[||•]==(86)==[•||]
Old 11-07-2016, 11:41 AM   #5
Apex-Apex
Apex-Apex's Avatar
I know someone that got his revo stuck on his extended studs.
IG: @apexapexapex
Old 11-07-2016, 02:16 PM   #6
Sosa
[||]--(86)--[||]
Sosa's Avatar
I agree with you that Revo's cannot be used with extended studs, only the iconix/R26 (not personal experience though, only research).
[||•]==(86)==[•||]
Old 11-08-2016, 11:32 AM   #7
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
It will not work. Have tried this before and they do NOT work!
ExxelDistributions is offline   Reply With Quote
The Following User Says Thank You to ExxelDistributions For This Useful Post:
Sosa (11-08-2016)
Old 11-08-2016, 04:21 PM   #8
Sosa
[||]--(86)--[||]
Sosa's Avatar
Looks like the search continues, thanks again for the info everyone!
[||•]==(86)==[•||]
FS: Project Kics R40 Lugnuts chopsu007 Wheels and Tires 4 05-18-2016 01:55 AM
Project Kics 3mm Spacers Cole Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-06-2016 02:18 PM
Project Kics r26 Swabe Wheels and Tires 1 06-15-2015 10:56 PM
Broken Project Kics R40 lug nut TylerLieberman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-13-2015 09:50 PM
FS project kics 40 lug nuts! jgonx213 Wheels and Tires 1 10-16-2014 07:06 PM
