Drives: Not running
What Parts Do You Wish Were Produced For the FR-S and BRZ?
What products would you like to see developed for both the FR-S and BRZ? Whether it be as small as custom door sills or as large as a bolt in 6 point cage (I realize these are both obtainable items), but I want to hear from everybody else!
Powered by Crickets
Drives: 14' SWP MT Limited BRZ
A fuel pump that doesn't chirp 😅
Sent from my Pixel using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Drives: car
revised throw out bearing for stock clutch
Not Bаnned Anymore
Drives: Heavily Modified FRS
I want to see some better gauge mounting options (high quality)
Some additional ideas in this thread
"New parts do you want to see manufactured" and If you could see Extreme Dimensions make a new part for frs/brz what would it be? There may be others. and oh yea... LOUVERS!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
Drives: 15FRS, 05MustangGT, 85Toyota truck
A steering wheel with only what I need on it...A horn button, and simple cruise control buttons...instead of the stupid buttons they've put on the 2017.
(I detest the current cruise control stalk beside the steering wheel...easily confused with the wiper stalk, and not intuitive [down to set and up to resume..odd] ). An engine under the hood which has some low rpm torque. Transmission and rear end gearing which will allow low rpms, running 90mph...for better gas mileage at freeway speeds. Oh sure, this is what you really wanted to hear... Last edited by ToySub1946; 11-07-2016 at 10:31 PM. |
Drives: red 2014 FR-S
since were dreaming about things that won't be made, then this.
Contract? /人◕ ‿‿ ◕人\
Drives: Subaru BRZ
A larger capacity engine as an option.
#10 |
Drives: 2016 Oceanic, "base" model
A CARB-legal, PNP, 3SGE engine swap kit.
#11 |
Drives: 2013 Scion FR-S Series 10
Optional interior color and fabric choices. Also, make the convertible version.
#12 |
Drives: Nissan Murano
STI trim with a 2.5 liter 240hp N/A engine that revs to the moon!
#13 |
Drives: 2016 Cosworth 2.2 BRZ
Get rid of the analog speedometer and replace it with oil temperature and pressure gauges that are calibrated in actual degrees. Put coolant temperature in degrees as well. Transmission temperature would be nice too.
Add some map lights instead of just the one overhead dome light. Add a rear dome light because you can never have enough light when you are digging through your car at night. Get rid of the trapezoid shaped factory radio and go to a standard double DIN with analog RCA preamp outputs for an aftermarket amplifier. Get rid of Starlink and support android/iphone mirroring. Drill cutouts in the frame so that you can replace the spark plugs without raising the engine. Heated steering wheel option would be nice. |
#14 |
OH HEY NOW!!!!
Drives: 2013 Scion Fr-s Asphalt
Stronger Studs
| Comparison of the best ~2 liter N/A engines ever produced | mit_peid | FR-S / BRZ vs.... | 331 | 07-30-2016 04:24 PM |
| Must See Hard Candy Shell produced from Modesta BC-04 on BMW M3 | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 06-11-2015 09:37 AM |
| New cars produced still suffering from first year issues? | Lord09 | Issues | Warranty | Recalls / TSB | 30 | 09-22-2013 06:32 PM |
| Frs not being produced in auto? | camelflage | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 04-17-2013 08:50 AM |
