Drives: 2015 Scion FR-S
Electric PS Settings?
Is there any adjustment available controlling the weight of the electric power steering? I know many features on the car can be adjusted using a laptop to adjust the computer default settings. I find the power steering a little too heavy for my taste. I wish it was 10% to 20% lighter. What do you-all think? Thanks.
Drives: Satin White BRZ Limited
I would recommend lighter wheels for a lighter steering feel. Also, you can play around with tire pressure. The higher the tire pressure, the lighter the steering wheel will feel. Stock psi is 35 cold. Try upping it to 37 PSI and see if that helps.
What wheel specs and what tires do you have? With my snow tires (205/50/17 Hankook iPike RS) on stock wheels the steering feel is way too light for my taste, but with the summer wheels/tires (17x8 +45 and 225/45/17 AD08R's) it's much better.
If your width and/or offset is much different than stock, or you're running stickier tires, it'll greatly increase steering effort.
| The Following User Says Thank You to wparsons For This Useful Post: | Cole (11-02-2016) |
#4 | |
Not a troll
Do you have stupid heavy wheels? As for your actual question, I haven't ever seen it come up on here. My best advice would be to find someone local to you who has tech stream or call your dealer and find out. |
| OEM Audio Plus settings | mush | Electronics | Audio | NAV | Infotainment | 16 | 08-23-2014 01:18 PM |
| Gopro settings | Chen | Northwest | 0 | 04-18-2014 02:43 PM |
| BRZ EQ Settings | Marcoscrdo | Electronics | Audio | NAV | Infotainment | 1 | 01-02-2013 04:35 PM |
| Settings for TCS and AT | atledreier | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-20-2012 09:36 AM |
| EQ settings | chadz | Electronics | Audio | NAV | Infotainment | 2 | 07-15-2012 09:18 PM |
