Old 10-21-2016, 04:44 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
MY17 New VDC “TRACK” – US Subaru Technicians help
As described here, a new management of traction and stability is performed in MY17. Minor changes are related only to switch on central console but the relevants are in VDC/VSC management.
When accessing in TIS (Techstream with J2534 read/write capable cable Mongoose official i.g.,or SSMIII) you can identify engine FW release and VDC FW release. Therefore you can upload new engine ecu fw and VSC too.
The questions:
#1. Is it downloadable (upon payment I suppose) the MY17 VDC/VSC FW?
#2. If positive, a prior MY17 board (car) can be upgraded?
Trap63 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trap63 For This Useful Post:
bhmax (10-21-2016), BWilky (10-28-2016), SuperDave (10-21-2016)
Old 10-21-2016, 03:09 PM   #2
KayoTrap
Has anyone confirmed if pedal dance works on the MY17s?
KayoTrap is offline   Reply With Quote
Old 10-28-2016, 02:29 AM   #3
WWFT86
Drives: 2017 BRZ Limited
Don't need to do it on MY17 -
Holding the "Traction-off" button (leftmost button, looks like a car with skidmark and the word "off" at bottom) for 3 seconds while he vehicle is stopped get you into an ALL-OFF (aka. You're on your own) mode -- This is what Toyota/Subaru intended for completely turning off TC and VSC. Brake LSD will be off as well if it's a MT but in an automatic transmission the Brake LSD will be in "TRACK mode" still. In the first gen FRS/BRZ with MT, Brake LSD remained on in this mode and often cause interference when the driver wants to take full control. This is perhaps why there was a need for the pedal dance
Indicator light so you know you're in this mode: "TRAC OFF" and "Car with skidmark with word OFF at bottom"
To turn off this mode, simply press the "Tracktion-off" button. This mode will also be turned off when:
- regular key-start vehicle -- engine switch is turned to "LOCK" position
- push-button-start vehicle -- push button ignition turned off
- note this mode will NOT turn off even after reaching 50km/h (~31 mph)
WWFT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to WWFT86 For This Useful Post:
tCsonfrs (11-08-2016), Trap63 (10-28-2016)
MY17 fuel pump chirping Impureclient Scion FR-S / Toyota 86 GT86 General Forum 80 01-22-2019 12:48 AM
Build Your Own BRZ Accessories (MY17) FlipperBizkut BRZ First-Gen (2012+) — General Topics 15 10-12-2016 05:48 PM
MY17 fuel pump chirping Impureclient BRZ First-Gen (2012+) — General Topics 13 10-11-2016 09:38 PM
DashCommand PRO Clusters MY13&MY17 NEW! Trap63 DIY (Do-It-Yourself) Guides 2 09-02-2016 03:34 PM
Subaru technicians on camera, wow DliciousFish Issues | Warranty | Recalls / TSB 32 07-01-2015 07:48 PM
