| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: SWP BRZ Limited Manual. 2014
Spray on Wax
Hey Guys,
I posted this on reddit too. Suggestions for spray-on wax for white? I park in an area with ton of Sun and pollen/sap. I want something that is high protectant, gloss isn't a goal for me. Optimum Spray on Wax https://smile.amazon.com/Optimum-SW2...ray%2Bwax&th=1 or Meguiar's D15601 X-Press? https://smile.amazon.com/Meguiars-D1...imum+spray+wax
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
Drives: 2015 FRS Asphalt
Optimum Spray Wax is what I use every few months. Easy to use & get Optimum Instant Detailer as well which provides more slick & gloss. I buy the concentrated instant detailer & mix with distilled water. The one bottle lasts for a year! I keep a bottle of it in my car to use for bird crap droppings. I buy both from Amazon. Just my 2 cents! 😎
Drives: car
I'm about to buy the gallon of X-Press Spray Wax, which apparently is the same as meguiar's normal spray was, just better value. I've had really good results with their spray wax, works really good for maintaining a full wax job.
#4 | ||
I forgot to mention that I want a carnauba wax alternative or substitute. I can only do it maybe once a year beccause it takes up so much time. I want something that'll add a layer of protection and easy to do since I'm willing to wipe down/wash my car once a month.
Thanks. Quote:
How is it on black parts of the car like the rubber and dark parts?
Drives: 13' BRZ
I can only chime in on Meguiar's D15601 X-Press Spray Wax as I have not used ON's wax before.
The BRZ gets a full detail twice a year, one in the fall before winter storms and another toward the end of spring when rains have stopped. In between the two full details that consist of polish/compound/sealant/wax, I use Meguiar's X-Press Spray Wax after each wash. **I typically wash my car every two weeks** Pros on this spray wax: 1) Smells good 2) Can be applied to the entire exterior (Glass + Plastics), interior trim/plastics also. 3) Doesn't stain plastics white like your normal wax. 4) Priced fairly cheap 5) Wax longevity is amazing. |
#6 | |
Drives: 13' BRZ
Regardless of product, you should think in this manner. The longer fallout sits on your paint, the tougher it is to remove it. My current catless setup deposits soot on the rear quarter panel/bumper/trunk after 3 to 4 days, much more noticeable by the second week. With X-Press wax applied, I use the pressure washer (electric type) and 90% of the soot is gone with one pass. The last 5% is removed via microfiber mitt/soap which requires almost no pressure. Hopefully that paints a picture as on the protection offered by X-Press wax. ^ See above post on black/plastic trim staining. |
Drives: car
@SmartedPanda no I don't think doing once a year maintenance with a spray wax is enough. If sap is a problem then your wash / wax process is going to be more urgent. And the whole time factor is such a cop out, it takes 30 minutes to fully wax this car after a wash.
Spray wax is more of a maintenance wax, it's super thin. And while using spray wax is faster than regular waxing, it's much faster to use after you've applied a base coat of wax first. In fact all wash / clean processes are faster after having a base coat of wax. I recommend using the spray wax after every wash though, it's worth it. |
Drives: car
@SmartedPanda protection all depends on the environment factor. I can have my car's look last for weeks if it doesn't rain and if I avoid construction site / yard work dust. But if it rains and gets dusty / polleny then it fades pretty quick. That's why I recommend using the spray wax after every wash (after first applying a base coat of wax).
#9 | |
How about syntheticwax? Any recommends for synthetic? I think it's also called sealant? I want longer protection then shine/gloss. Thanks for your input and bumps
#10 |
carnuba wax is good, but it doesn't last as long as some other synthetic waxes. I would say a good carnuba wax would last a month or two while some other waxes/sealants would last up to half a year. regardless, I still use carnuba wax on every other car wash I do while I use a detailer sealant spray on the washes I don't wax. I only wash my car once it gets dirty and not on a schedule like other people though. I park in a garage so it works out well for me. it probably averages out to about once every month to two months.
I use this wax: https://www.amazon.com/P21S-12700W-C...&keywords=p21s and this sealant: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#11 | |
Drives: car
Sealants should be your base for protection. You want to start with a perfectly clean car (washed, clay barred, iron-x'd, dual-action compounded) before applying your sealant. I've used Meguiar's Ultimate Wax which is synthetic, in both paste and liquid. Both are good kits and the included microfiber is nice. I prefer the liquid over the paste because there's less chance of contamination over time. You should thoroughly clean and reapply sealants maybe once every year maybe more. |
#12 |
If you're looking at just waxing once or twice year then invest in getting your car ceramic coated with Optimum Opticoat Pro or their new one called Gloss Coat. It's the best $400.00 I spent on my car. Makes washing the car so much easier as the water just sheets off the car. You won't need to wax at all if that's what you don't wanna do often. More slick and gloss just use Optimum Instant Detailer. My car is in the sun 24/7 as I have no garage and sits out at work as well.
Take a look at the Optimum forum. http://optimumforums.org/ |
#13 |
Drives: 2016 frs
Just putting in my 2 cents. I use meguires products. However I do it on a regular basis. ( the spray wax that is) you can pick it up at your local automotive store. It's pretty good ( in my opinion) and works great to get small amounts of dirt , grime and pollen off. I always have a bottle on me. Maybe $15 + a pack of microfiber. Not a 1 year shine but last you atleast a week or two
#14 |
Drives: N/A
If I had to only rely on a spray wax to protect my car I would 100% go with Optimum Spray Wax, and here is why. First and most importantly Optimum Spray Wax has 2 patents for UV protection. As I am sure you know UV damage is a major contributor to clear coat failure. I find the product extremely easy to apply, takes about 15 minutes with two microfiber towels, one "wet" from product and one "dry" to buff. I easily think you could apply it after every wash in 15 mins time and a benefit you can apply the product to all trim and molding's as well to protect them.
| Red Tint Spray | RedFR-s | CANADA | 5 | 03-22-2016 01:14 PM |
| Detailer spray? | Tea86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 18 | 10-21-2014 07:27 PM |
| anyone have a paint spray gun? | m.box.design | Northwest | 1 | 06-01-2014 04:07 PM |
| 30% off the BEST Detail Spray while supplies last - Adam's Detail Spray | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 02-11-2013 06:51 PM |
| Anyone tried this wheel spray? | luv85 | AUSTRALIA | 13 | 10-22-2012 09:39 PM |
