Old 10-15-2016, 02:07 PM   #1
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
TRD rear bumper + skirts cutting / fitting templates
Fitted my TRD kit yesterday, it came with the cutting template for the bumper and the fitting template for the skirts. While you can find the manual easily online, you can't find the templates (or atleast I couldn't). I decided to store the templates for future reference, and then why not share it with the community
I've scanned them both on one A4, available for download see attachment
And why not share a pic of the kit fitted too
Installation was very straight forward, fitment 100%, no issues whatsoever. Just the skirts leave some room for 'guessing/preference' on how high you want them. I've put them as near to the door as possible. Also for the rear lip, there is no need to remove the rear bumper from the car, just take it easy and you can fit the whole thing while still on the car. Just make sure you don't cut the fog/reverse light wires.
Vin is offline   Reply With Quote
Old 10-15-2016, 06:05 PM   #2
electrongeek
Drives: 2016 Scion FRS
Finally!! I've been searching the past couple months and have held off on the rear since I didn't want to cut without a template.
Thank you so much for doing this!! Now I can finish my install.
electrongeek is offline   Reply With Quote
Old 10-16-2016, 03:56 AM   #3
Vin
Vin's Avatar
Glad I could help. Also use the L shaped piece. It will tell you how high the rear should sit.
Old 10-16-2016, 04:25 PM   #4
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
It actually looks really nice without a quad tip in there!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 10-17-2016, 12:49 PM   #5
Vin
Vin's Avatar
From the side angle, yes, straight from behind, not so much:
It looks a bit lost ..
Old 05-20-2017, 02:13 AM   #6
kevin.nguyen
Drives: Ultramarine FRS
Hi,
For the template, do we just print it on regular 8.5x11 in. paper? Also, do you have a link for the manual. I don't exactly see where the templates would be placed.
Thank you
kevin.nguyen is offline   Reply With Quote
Old 04-21-2018, 01:49 AM   #7
Vin
Vin's Avatar
Hi
The manual can be found here : https://www.google.nl/url?sa=t&sourc...W2Yme0u5mgWftC
The template is a4. The cutting template fits snug around the exhaust cutout, as you can see in the manual , so if you printed with wrong scaling it will show
Old 04-21-2018, 02:18 AM   #8
Allen Poe
AT Pleb
Allen Poe's Avatar
Drives: 2014 FR-S Monogram (Firestorm Red)
Wait, so i have to cut into the bumper if I want to install the TRD kit? *crosses it off the list*
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad.
Allen Poe is offline   Reply With Quote
Old 04-21-2018, 02:37 PM   #9
DigitalVeil92
Drives: Maybe 2015 FR-S
Originally Posted by Vin View Post
Hi
Thank you so much!! I've been looking EVERYWHERE for an english version of the instructions because trying to figure it out from just pictures was a hell of a time, I'm so happy there's an english version lol
DigitalVeil92 is offline   Reply With Quote
Old 04-22-2018, 03:06 AM   #10
Vin
Vin's Avatar
Yes otherwise those quad pipes wil never fit
Old 01-02-2021, 12:59 AM   #11
Emilios frs
Drives: 2013 Scion frs
Need your help
So my diffuser is all the way cut off I have no diffuser at all & I want to buy this bumper, is there any way you can walk me threw it like giving me some steps on how to do it since I don’t have a diffuser I figure it will be easier to install, will I only have to screw it in & use the 3m tape or is there more to it?
Emilios frs is offline   Reply With Quote
Old 04-24-2021, 10:07 PM   #12
Gloonge
Drives: 2013 frs raven
If your diffuser is completely removed it is as simple as mounting the double sided tape to the bumper cover, installing the bottom clips, lining up the cover, installing the tapping screws in the fender well and then remove the film off the double sided tape and stick it to the og bumper in stages.
Super late to the party, but hope it helps if you have not done it yet.
Gloonge is offline   Reply With Quote
TRD bumper garnish fitting instructions in English APS86 Cosmetic Modification (Interior/Exterior/Lighting) 9 11-16-2018 11:29 AM
Anyone have the OFT templates unlimited86 Software Tuning 6 08-23-2016 07:30 PM
TRD Side Skirts, Front Bumper Scuba86 Cosmetic Modification (Interior/Exterior/Lighting) 1 02-26-2015 06:52 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 11:08 AM
