Old 10-15-2016, 12:03 PM   #1
ss4max
Highbeam Tap
I have searched for days for a solution, maybe I'm blind, but is there anywhere I can tap for 12v highbeams? I know the DRL and highbeams are one for the stock harness. I need a dedicated 12v for highbeams. Planning on wiring my garage door opener to it. All things done except for this...
ss4max is offline   Reply With Quote
Old 10-15-2016, 12:44 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
If u want it 12v or nothing, u need to have dealer disable the DRL
lbroskee is offline   Reply With Quote
Old 10-15-2016, 01:17 PM   #3
ss4max
There isn't a wire on the inside either? Like around the steering column?
Old 10-15-2016, 02:50 PM   #4
lbroskee
lbroskee's Avatar
There may b and then a relay further along, but I've never pulled that part of the car open. Ur trying to set a flick to open the door I take it? If that's the case, y not do it on the traction button since a click of that is the same idea as a quick hi beam flash (if u only need it powered for a second that is)
Old 10-15-2016, 04:10 PM   #5
ss4max
I could do that, but I doubt there's enough room for the box I have the opener in.
Old 10-15-2016, 04:58 PM   #6
lbroskee
lbroskee's Avatar
There is surprisingly A lot of space down there. And if it's still not enough you could always just run extra wire and relocate the box somewhere else
Old 10-15-2016, 05:25 PM   #7
ss4max
I'll check that out. I think I'll run a transistor with low beam as the power source and the drl the trigger, since high beam triggers both. I'll lyk if it works out.
Old 10-22-2016, 01:20 PM   #8
ss4max
I wired it the way I said but with a relay instead and it works like a charm.
highbeam
frs grille, 2 pairs of HID highbeam bulbs, grimspeed license plate frame ALL for $40 ndreim Canada Classifieds 4 10-18-2016 06:04 PM
Trouble replacing highbeam bulbs JBALES Cosmetic Modification (Interior/Exterior/Lighting) 1 10-13-2014 12:37 PM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
