Old 10-13-2016, 01:41 PM   #1
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Header Nuts
Quick question for those of you who replaced the stock nuts when installing aftermarket headers. I'm going to be re-installing the OFH this weekend but wanted to replace the stock nuts since the last time they kept coming loose. I know they are 14mm but wanted to know anyone knows exactly what kind they are? I'm not sure you can just grab any 14mm ones and put them on.
As always, thanks for your help!
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 10-13-2016, 02:02 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
cant say what kind per se but i do know there different thread pitches for nuts & bolts can exist. example- the amount of threads per linear inch and the angle of the valleys/peaks can change. if not matching it will strip something if you brute force it.
Old 10-13-2016, 02:25 PM   #3
ap5512
ap5512's Avatar
correct - I tried looking on subaru OEM parts to see if it's something i can get at the dearlership but not sure I found anything substantial. I'm hoping someone can chime in and let me know exactly. also, the bottom are flat and have ridges for locking maybe?
Old 10-13-2016, 03:24 PM   #4
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Use a M10 x 1.25 metal lock nut and you won't have any issues
JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
ap5512 (10-13-2016), DAEMANO (10-14-2016), sroby (09-23-2019)
Old 10-13-2016, 04:19 PM   #5
ap5512
ap5512's Avatar
Thank you @JDLAutoDesign ! I'll go to the auto/hardware store to see what they have.
Old 10-13-2016, 06:26 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you are using brand new stock nuts, you won't have an issue.
If you reuse stock nuts, they'll back out.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
ap5512 (10-14-2016)
Old 10-13-2016, 08:24 PM   #7
Amputechture
Drives: 2014 BRZ
Had the same problem, get one of those jokers with nylon/elastic so they won't back out and you'll be worry free.
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
ap5512 (10-14-2016)
Old 10-14-2016, 01:26 AM   #8
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Not sure about using nylon lock nuts on hot exhaust though....they might melt? When I installed my turbo manifold I used these titanium lock nuts instead. Holding strong so far and no leaks.
https://www.probolt-australia.com/ti...et-of-6-1.html
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
ap5512 (10-14-2016)
Old 10-14-2016, 02:03 AM   #9
steve99
never had a problem with stock nuts comming loose
use new gaskets and also put some high temp anti seize on nuts and studs, work nut over threads couple of times and then wipe off excess antizeize and any rust or dirt.
apply some fresh antiseize then torque up nuts to specified torque
start car and let it run for a few minutes then retorque
if you just torque up dirty or rusty nuts most of the torque is used to overcome the rust and dirts on threads, then once they heat up they will come loose.
if their nice and free with a bit of antiseize then your actually applying the correct torque and they should be fine.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
ap5512 (10-14-2016), DHitHim (10-14-2016), mav1178 (10-14-2016)
Old 10-14-2016, 10:26 AM   #10
ap5512
ap5512's Avatar
The original nuts kept on coming loose the first time i installed the header and i could tell right away because the noise was different each time i drove. I used anti-seize after i got tired of retightening every weekend but this time im thinking of getting new nuts and using anti-seize (after cleaning everything). Thanks for the help guys!
*Sold* please delete xwd Engine, Exhaust, Bolt-Ons 24 03-15-2017 09:19 AM
Back to stock header - lost nuts Khyron686 Engine, Exhaust, Transmission 3 08-24-2016 12:30 AM
Overpipe to Header Bolts/Nuts 808BRZ Engine, Exhaust, Transmission 2 07-25-2016 08:41 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
